Aller au contenu principal
Acer Aspire V5-131-2629 Hard Drive Replacement
Ce dont vous avez besoin
  1. Acer Aspire V5-131-2629 Hard Drive Replacement, Battery: étape 1, image 1 de 1
    • Carefully turn your Acer Aspire V5-131-2629 upside down, so that the battery cell is visible and nearest to you.
  2. Acer Aspire V5-131-2629 Hard Drive Replacement: étape 2, image 1 de 1
    • Identify the small, oval slide switch on the left hand side of the laptop, directly above the battery.
  3. Acer Aspire V5-131-2629 Hard Drive Replacement: étape 3, image 1 de 1
    • Insert an opening tool into the hole on the right side of the oval switch. Use the opening tool to slide the switch to the right.
  4. Acer Aspire V5-131-2629 Hard Drive Replacement: étape 4, image 1 de 2 Acer Aspire V5-131-2629 Hard Drive Replacement: étape 4, image 2 de 2
    • With the switch engaged to the right, firmly pull the battery out and towards yourself, parallel to your work surface.
  5. Acer Aspire V5-131-2629 Hard Drive Replacement, Cover: étape 5, image 1 de 1
    • Remove the single Phillips #0 screw from the cover on the underside of the laptop.
  6. Acer Aspire V5-131-2629 Hard Drive Replacement: étape 6, image 1 de 2 Acer Aspire V5-131-2629 Hard Drive Replacement: étape 6, image 2 de 2
    • Remove the cover by sliding it outwards and remove it from the device.
  7. Acer Aspire V5-131-2629 Hard Drive Replacement, Hard Drive: étape 7, image 1 de 1
    • Locate the large blue hard drive on the left side on the computer.
  8. Acer Aspire V5-131-2629 Hard Drive Replacement: étape 8, image 1 de 1
    • Gently pull out the ribbon cable on the computer-attached end.
  9. Acer Aspire V5-131-2629 Hard Drive Replacement: étape 9, image 1 de 1
    • Completely remove the hard drive from the hard drive bay.
  10. Acer Aspire V5-131-2629 Hard Drive Replacement: étape 10, image 1 de 2 Acer Aspire V5-131-2629 Hard Drive Replacement: étape 10, image 2 de 2
    • Remove the two screws on the side of the hard drive cage.
  11. Acer Aspire V5-131-2629 Hard Drive Replacement: étape 11, image 1 de 2 Acer Aspire V5-131-2629 Hard Drive Replacement: étape 11, image 2 de 2
    • Pull the hard drive cage from the hard drive to separate the two.
4 autres ont terminé cette réparation.
Nicole B Bosse
Membre depuis le 10/27/19
175 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S1-G3, O'Connell Fall 2019 Membre de l'équipe UMass Dartmouth, Team S1-G3, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G3
3 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 9
30 derniers jours : 33
Total : 1,415
