Introduction
The following guide summarizes information to replace the wireless adapter in the Acer Aspire V5-131-2629.
If your Acer Aspire does not show an available network or has a frequent failure to connect Wi-Fi, there is a chance that the wireless adapter is in need of replacement.
Be sure to test your wireless adapter and your connection before deciding to go through with the replacement process shown in this guide.
Ce dont vous avez besoin
Carefully turn your Acer Aspire V5-131-2629 upside down, so that the battery cell is visible and nearest to you.
Remove the single Phillips #0 screw from the cover on the underside of the laptop.
Remove the black and white cables that are attached to the Wi-Fi card.
