Aller au contenu principal
Acer Aspire V5-131-2629 Wireless Adapter Replacement
Ce dont vous avez besoin
  1. Acer Aspire V5-131-2629 Wireless Adapter Replacement, Battery: étape 1, image 1 de 1
    • Carefully turn your Acer Aspire V5-131-2629 upside down, so that the battery cell is visible and nearest to you.
  2. Acer Aspire V5-131-2629 Wireless Adapter Replacement: étape 2, image 1 de 1
    • Identify the small, oval slide switch on the left hand side of the laptop, directly above the battery.
  3. Acer Aspire V5-131-2629 Wireless Adapter Replacement: étape 3, image 1 de 1
    • Insert an opening tool into the hole on the right side of the oval switch. Use the opening tool to slide the switch to the right.
  4. Acer Aspire V5-131-2629 Wireless Adapter Replacement: étape 4, image 1 de 2 Acer Aspire V5-131-2629 Wireless Adapter Replacement: étape 4, image 2 de 2
    • With the switch engaged to the right, firmly pull the battery out and towards yourself, parallel to your work surface.
  5. Acer Aspire V5-131-2629 Wireless Adapter Replacement, Cover: étape 5, image 1 de 1
    • Remove the single Phillips #0 screw from the cover on the underside of the laptop.
  6. Acer Aspire V5-131-2629 Wireless Adapter Replacement: étape 6, image 1 de 2 Acer Aspire V5-131-2629 Wireless Adapter Replacement: étape 6, image 2 de 2
    • Remove the cover by sliding it outwards and remove it from the device.
  7. Acer Aspire V5-131-2629 Wireless Adapter Replacement, Wireless Adapter: étape 7, image 1 de 1
    • Remove the black and white cables that are attached to the Wi-Fi card.
  8. Acer Aspire V5-131-2629 Wireless Adapter Replacement: étape 8, image 1 de 2 Acer Aspire V5-131-2629 Wireless Adapter Replacement: étape 8, image 2 de 2
    • Remove the single Phillips screw securing the Wi-Fi card.
    • The wireless adapter will pop out at a 45 degree angle.
  9. Acer Aspire V5-131-2629 Wireless Adapter Replacement: étape 9, image 1 de 1
    • Pull on the wireless adapter to remove it and replace it.
Aaron Almeida
Membre depuis le 10/25/19
551 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G3, O'Connell Fall 2019 Membre de l'équipe UMass Dartmouth, Team S1-G3, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G3
3 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 12
Total : 677
