Aller au contenu principal
Acer Aspire V5-131-2680 Hard Drive Replacement
  1. Acer Aspire V5-131-2680 Hard Drive Replacement, Bottom Cover: étape 1, image 1 de 1
    • Make sure your laptop is powered down and completely closed before proceeding.
    • Turn your laptop upside down. The stickers should be facing up.
  2. Acer Aspire V5-131-2680 Hard Drive Replacement: étape 2, image 1 de 2 Acer Aspire V5-131-2680 Hard Drive Replacement: étape 2, image 2 de 2
    • To open the bottom compartment, put one finger underneath the laptop and firmly grab the compartment with your thumb.
    • You can also use both thumbs for more pressure.
    • Carefully slide the bottom compartment with your thumb until you feel it pop out of place.
  3. Acer Aspire V5-131-2680 Hard Drive Replacement, Hard Drive: étape 3, image 1 de 2 Acer Aspire V5-131-2680 Hard Drive Replacement, Hard Drive: étape 3, image 2 de 2
    • On the sides of the hard drive, you will see two side tabs. This is what holds the hard drive in place.
    • Place your finger on the left tab and press on it to loosen the hard drive.
    • After the hard drive is loose, slide it out of the compartment.
    • Do not remove your finger from the side tab while removing the hard drive.
  4. Acer Aspire V5-131-2680 Hard Drive Replacement: étape 4, image 1 de 1
    • You have successfully removed the hard drive from the laptop.
Mauricio Moreno
Membre depuis le 09/26/22
601 Réputation
5 tutoriels rédigés
Équipe
CSU Los Angeles, Team 6-1, Adachi Fall 2022 Membre de l'équipe CSU Los Angeles, Team 6-1, Adachi Fall 2022
CSULA-ADACHI-F22S6G1
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 14
Total : 189
