Aller au contenu principal
Acer Aspire V5-131-2680 Screen Replacement
Ce dont vous avez besoin
  1. Acer Aspire V5-131-2680 Screen Replacement, Screen: étape 1, image 1 de 1
    • Open up your laptop.
    • Place an opening tool in the crack between the screen and the back compartment. Drag the opening tool throughout the crack to open.
    • Remove the front black frame of the laptop.
  2. Acer Aspire V5-131-2680 Screen Replacement: étape 2, image 1 de 1
    • Use a JIS #1 screwdriver to remove the 10 marked M2 x 3 Phillips screws.
    • Use a magnetic bit to fully remove the screws from their locations.
  3. Acer Aspire V5-131-2680 Screen Replacement: étape 3, image 1 de 1
    • Remove then aluminum frame holding the screen in place.
    • This frame may have some sharp edges. Lift and remove slowly.
  4. Acer Aspire V5-131-2680 Screen Replacement: étape 4, image 1 de 1
    • Carefully peel off the tape surrounding the screen.
  5. Acer Aspire V5-131-2680 Screen Replacement: étape 5, image 1 de 1
    • Unplug the pin conector from the display.
    • This is a sensitive piece. Do not grab harshly or the pin can break.
    • The screen is now free to be removed.
Mauricio Moreno
Membre depuis le 09/26/22
601 Réputation
5 tutoriels rédigés
Équipe
CSU Los Angeles, Team 6-1, Adachi Fall 2022 Membre de l'équipe CSU Los Angeles, Team 6-1, Adachi Fall 2022
CSULA-ADACHI-F22S6G1
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 110
