Aller au contenu principal
Acer Aspire V5-473P-5602 Touchpad Replacement
Ce dont vous avez besoin
  1. Acer Aspire V5-473P-5602 Touchpad Replacement, Back Panel: étape 1, image 1 de 2 Acer Aspire V5-473P-5602 Touchpad Replacement, Back Panel: étape 1, image 2 de 2
    • Flip the laptop over so the back panel is facing upwards.
    • Use the Phillips #0 screwdriver to remove seventeen 2.5mm screws.
    • Remove the back panel from the laptop using an iFixit opening tool.
  2. Acer Aspire V5-473P-5602 Touchpad Replacement, Battery: étape 2, image 1 de 2 Acer Aspire V5-473P-5602 Touchpad Replacement, Battery: étape 2, image 2 de 2
    • Remove the Phillips #0 screw from the middle of the battery.
  3. Acer Aspire V5-473P-5602 Touchpad Replacement: étape 3, image 1 de 1
    • Unplug the battery from the motherboard.
  4. Acer Aspire V5-473P-5602 Touchpad Replacement: étape 4, image 1 de 1
    • Carefully take the battery out of the device.
  5. Acer Aspire V5-473P-5602 Touchpad Replacement, Touchpad: étape 5, image 1 de 1
    • Use a spudger to remove the aluminum foil tape from the touchpad.
  6. Acer Aspire V5-473P-5602 Touchpad Replacement: étape 6, image 1 de 1
    • Unplug the cable from the touchpad.
  7. Acer Aspire V5-473P-5602 Touchpad Replacement: étape 7, image 1 de 1
    • Remove ten Phillips #0 screws securing the touchpad to the base.
  8. Acer Aspire V5-473P-5602 Touchpad Replacement: étape 8, image 1 de 1
    • Use the pointed end of a spudger to remove the small triangular metal piece.
  9. Acer Aspire V5-473P-5602 Touchpad Replacement: étape 9, image 1 de 2 Acer Aspire V5-473P-5602 Touchpad Replacement: étape 9, image 2 de 2
    • Use the spudger to lift up the touchpad carefully.
    • Remember to use electronic cleaner to clean the touchpad screen surface before placing the new touchpad back in.
Thuy Tran
Membre depuis le 01/22/20
267 Réputation
2 tutoriels rédigés
Équipe
York University, Team S8-G6, Turner Winter 2020 Membre de l'équipe York University, Team S8-G6, Turner Winter 2020
YORK-TURNER-W20S8G6
5 membres
21 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 13
Total : 323
