Introduction
This guide will take a user through the replacement of the hard of drive.
Pièces
Aucune pièce nécessaire.
Use a J0 JIS screwdriver to remove 17 7mm screws from the back case. They can be located on the underside of the device.
  • Use a J0 JIS screwdriver to remove 17 7mm screws from the back case. They can be located on the underside of the device.
Ajouter un commentaire
Remove the plastic tab on the left edge of the device.
  • Remove the plastic tab on the left edge of the device.
  • Lift up the back case to remove it.
  • The first thing that should be done it locate the the hard drive.Which is the large green blue rectangle on the left side
  • The removal of the hard drive is actually a fairly easy thing to remove the only step is that the user should pull the black bundle cable from its slot by its purple tab.
  • And then simple lift and remove and thats it the hard drive has been removed from its slot and is ready for its replacement.
Anthony hough
Membre depuis le 20/09/2017
101 Réputation
1 tutoriel rédigé
Équipe
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 7
Total : 69
