Aller au contenu principal
Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement
Ce dont vous avez besoin
Vidéo d'introduction
  1. Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement, Keyboard: étape 1, image 1 de 3 Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement, Keyboard: étape 1, image 2 de 3 Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement, Keyboard: étape 1, image 3 de 3
    • Turn off the laptop and remove the battery.
    • Remove two screws securing the Keyboard.
    • The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
  2. Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement: étape 2, image 1 de 3 Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement: étape 2, image 2 de 3 Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement: étape 2, image 3 de 3
  3. Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement, Upper  Cover: étape 3, image 1 de 3 Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement, Upper  Cover: étape 3, image 2 de 3 Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement, Upper  Cover: étape 3, image 3 de 3
    • Remove 4x phillips screws and disconnect:
    • Power On button flex cable
    • Touch pad flex cable
    • Remove 18x Phillips screws from the bottom cover.
    • Remove any memory SD Card from the Card reader.
    • Start opening with a plastic opening tool.
  4. Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement: étape 4, image 1 de 3 Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement: étape 4, image 2 de 3 Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement: étape 4, image 3 de 3
    • Carefully separate the upper cover and remove it.
  5. Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement, HDD (Hard Disk Drive): étape 5, image 1 de 3 Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement, HDD (Hard Disk Drive): étape 5, image 2 de 3 Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement, HDD (Hard Disk Drive): étape 5, image 3 de 3
32 autres ont terminé cette réparation.
ZFix
Membre depuis le 12/09/13
191 882 Réputation
330 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
321 membres
1 516 tutoriels rédigés
6 commentaires
Good job! What a pain, though, to swap the HDD :)
Steve Wojciechowski - Réponse
I am currently working on this laptop and it doesn't open at all like this one. This is only one back... and 18 screws holding it on. I can partially snap the back off but i can't pry it apart by the dvd drive. I'm also guessing the same model is manufactured differently for different retailers. (This happens in the retail hardware world where a dewalt drill from home depot will be made cheaper than a dewalt from ace hardware) so now I"m stuck. any ideas would be helpful. thanks.
FallenAnjel - Réponse
ok found the problem. i accidentally popped out the dvd drive (when I was just trying to open it lol) and up under the lip I found three 1/8" long very-flat head screws. unscrewed those and the back came right off.
New customer that does like shopping local with recommended proprietors and stockiest of the required components.
Thank you Mr Jason Paul Cominelli.
Jason Paul Cominelli - Réponse
are 9mm hard disk can fit?
the original was 7mm
jason.chiah1008 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 26
30 derniers jours : 105
Total : 69,739
