Aller au contenu principal
Acer Aspire V5-571-6889 Motherboard Replacement
Ce dont vous avez besoin
  1. Acer Aspire V5-571-6889 Motherboard Replacement, Hard Drive: étape 1, image 1 de 1
    • Flip laptop over so that the back is facing upward.
    • Push switch to the right.
    • Pull battery away from the laptop.
  2. Acer Aspire V5-571-6889 Motherboard Replacement: étape 2, image 1 de 1
    • Use a #0 Phillips head screw driver to remove all of the screws.
  3. Acer Aspire V5-571-6889 Motherboard Replacement: étape 3, image 1 de 1
    • Flip laptop back over.
    • Open the laptop.
    • Wedge a prying tool between the keyboard and laptop body seam to remove keyboard.
    • Be careful not to bend the keyboard too much or break the tabs that connect the keyboard to the laptop.
  4. Acer Aspire V5-571-6889 Motherboard Replacement: étape 4, image 1 de 1
    • Gently lift keyboard.
    • Disconnect keyboard from the laptop.
  5. Acer Aspire V5-571-6889 Motherboard Replacement, Remove Upper Cover: étape 5, image 1 de 1
    • Disconnect the two ribbon cables at the near left.
    • Remove six screws: ⁃ one by the left most ribbon cable connector ⁃ one mid-right center ⁃ one on the near edge left of center ⁃ three across the back
    • Use a prying tool to remove the upper cover.
  6. Acer Aspire V5-571-6889 Motherboard Replacement: étape 6, image 1 de 1
    • Locate the hard drive.
    • Lift the hard drive.
    • Disconnect hard drive.
  7. Acer Aspire V5-571-6889 Motherboard Replacement, Motherboard: étape 7, image 1 de 1
    • Use #0 Phillips screw driver to remove the 2.5 x 5 mm with screw attached to the Motherboard.
  8. Acer Aspire V5-571-6889 Motherboard Replacement: étape 8, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Use Tweezers to remove the antenna cables attached to the Wi-Fi card.
  9. Acer Aspire V5-571-6889 Motherboard Replacement: étape 9, image 1 de 1
    • Use #0 Phillips screw driver to remove the two 2.5 x 5 mm Phillips #0 screws connecting the Wi-Fi card to the Motherboard.
  10. Acer Aspire V5-571-6889 Motherboard Replacement: étape 10, image 1 de 1
    • Lift and pull out the Wi-Fi card.
  11. Acer Aspire V5-571-6889 Motherboard Replacement: étape 11, image 1 de 1
    • Use #0 Phillips screw driver to remove the 2.5 x 5 mm Phillips #0 screw on the CD-ROM Drive.
  12. Acer Aspire V5-571-6889 Motherboard Replacement: étape 12, image 1 de 1
    • Lift and pull out the CD-ROM Drive.
  13. Acer Aspire V5-571-6889 Motherboard Replacement: étape 13, image 1 de 1
    • Use #0 Phillips screw driver to remove the 2 x 3 mm Phillips #0 screw holding down CD-ROM connector.
  14. Acer Aspire V5-571-6889 Motherboard Replacement: étape 14, image 1 de 1
    • Pull out the CD-ROM Drive connector.
  15. Acer Aspire V5-571-6889 Motherboard Replacement: étape 15, image 1 de 2 Acer Aspire V5-571-6889 Motherboard Replacement: étape 15, image 2 de 2
    • Use Tweezers to remove the tape covering the display cable connector.
    • Gently disconnect the display cable connector.
  16. Acer Aspire V5-571-6889 Motherboard Replacement: étape 16, image 1 de 1
    • Gently peel back the black cloth tape holding the wires in place.
  17. Acer Aspire V5-571-6889 Motherboard Replacement: étape 17, image 1 de 1
    • Gently lift Motherboard.
    • Do not remove yet. There are some connections that need to be disconnected.
  18. Acer Aspire V5-571-6889 Motherboard Replacement: étape 18, image 1 de 1
    • Gently remove the connector underneath the Motherboard.
  19. Acer Aspire V5-571-6889 Motherboard Replacement: étape 19, image 1 de 3 Acer Aspire V5-571-6889 Motherboard Replacement: étape 19, image 2 de 3 Acer Aspire V5-571-6889 Motherboard Replacement: étape 19, image 3 de 3
    • Gently disconnect the three connectors attached to the Motherboard.
  20. Acer Aspire V5-571-6889 Motherboard Replacement: étape 20, image 1 de 1
    • Use #0 Philips screw driver to unscrew the three 2.5 mm x 4 mm screws connecting the CPU fan to the Motherboard.
  21. Acer Aspire V5-571-6889 Motherboard Replacement: étape 21, image 1 de 1
    • The motherboard is ready to be replaced.
    • Attach the CPU fan to the new motherboard during reassembling.
Samuel Miguel
Membre depuis le 07/08/19
241 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S2-G4, Harley Summer 2019 Membre de l'équipe IUPUI, Team S2-G4, Harley Summer 2019
IUPUI-HARLEY-SU19S2G4
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 15
Total : 605
