Aller au contenu principal
Acer Aspire V5-591G-75KE Hard Drive Replacement
Ce dont vous avez besoin
  1. Acer Aspire V5-591G-75KE Hard Drive Replacement, Acer Aspire V5-591G-75KE Disassembly: étape 1, image 1 de 3 Acer Aspire V5-591G-75KE Hard Drive Replacement, Acer Aspire V5-591G-75KE Disassembly: étape 1, image 2 de 3 Acer Aspire V5-591G-75KE Hard Drive Replacement, Acer Aspire V5-591G-75KE Disassembly: étape 1, image 3 de 3
    • Close down the display and flip the device upside down.
    • Use a Phillips #1 screwdriver to remove 18 black 10mm Phillips Head screws in order to loosen up the protective bottom casing.
  2. Acer Aspire V5-591G-75KE Hard Drive Replacement: étape 2, image 1 de 2 Acer Aspire V5-591G-75KE Hard Drive Replacement: étape 2, image 2 de 2
    • With the screws removed, flip the device right-side up and open up the display.
    • Run a plastic spudger tool along the seam of the face-plate in order to loosen up the protective bottom casing.
    • Popping sounds are normal, but forceful prying can damage delicate components. Be especially careful near the USB and HDMI ports.
  3. Acer Aspire V5-591G-75KE Hard Drive Replacement: étape 3, image 1 de 2 Acer Aspire V5-591G-75KE Hard Drive Replacement: étape 3, image 2 de 2
    • Close the display down once more, and flip the laptop upside down, with the hinge facing away from you.
    • Do not yank the bottom casing off. There is a small speaker wire that connects it to the motherboard.
    • Taking note of the small speaker wire, gently lift only the left side of the bottom casing.
  4. Acer Aspire V5-591G-75KE Hard Drive Replacement: étape 4, image 1 de 3 Acer Aspire V5-591G-75KE Hard Drive Replacement: étape 4, image 2 de 3 Acer Aspire V5-591G-75KE Hard Drive Replacement: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    • Using a pair of blunt tweezers, push on the tabs of the small white connector to separate it from the motherboard.
    • The entire bottom casing should lift with no resistance. If there is too much resistance, verify you removed all the screws, and run the plastic spudger tool around the face-plate again.
  5. Acer Aspire V5-591G-75KE Hard Drive Replacement, Hard Drive: étape 5, image 1 de 3 Acer Aspire V5-591G-75KE Hard Drive Replacement, Hard Drive: étape 5, image 2 de 3 Acer Aspire V5-591G-75KE Hard Drive Replacement, Hard Drive: étape 5, image 3 de 3
    • Using the plastic tabs, lift the hard drive slightly and pull to the left.
    • Remove the rubber mounting brackets from the hard drive.
    • If you are replacing your hard drive with a new one, please note you will need to reuse the rubber mounting brackets in order to secure it in place.
Reina Godeck
Membre depuis le 10/16/17
741 Réputation
5 tutoriels rédigés
Équipe
UW Tacoma, Team S3-G5, Liner Fall 2017 Membre de l'équipe UW Tacoma, Team S3-G5, Liner Fall 2017
UWT-LINER-F17S3G5
4 membres
18 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 17
Total : 1,194
