Introduction
If the Acer Chromebook 14 CB3-431-C7EX is experiencing problems related to the trakpad, use this guide to replace the trackpad.
The trackpad of the Acer Chromebook 14 allows users to move the cursor using their fingers as well as utilize the clicking function. A faulty trackpad may cause the Acer Chromebook 14 to have a jittery cursor, complete loss of cursor control, or loss of the click function on the trackpad.
Before buying a replacement trackpad, use the guide to ensure that the trackpad is properly connected within the laptop. You may be able to fix this issue by reconnecting a loose connector.
Before beginning, be sure to power down the laptop, and unplug from the external power source(s).
Ce dont vous avez besoin
Use a Phillips #0 screwdriver to unscrew the eight 4mm screws.
Use a Phillips #0 screwdriver to unscrew the two 7mm screws.
Remove the cover of the device by prying up from one of the edges with a spudger or plastic opening tool.
2 autres ont terminé cette réparation.
Un commentaire
Thanks for this guide. You have helped a non-techie look oh so impressive with his repair skills!
