Aller au contenu principal
Acer Chromebook C710-2847 Wireless Card Replacement
Ce dont vous avez besoin
  1. Acer Chromebook C710-2847 Wireless Card Replacement, Battery: étape 1, image 1 de 2 Acer Chromebook C710-2847 Wireless Card Replacement, Battery: étape 1, image 2 de 2
    • Place the laptop on a flat surface with the bottom side facing up.
    • Place the tip of a spudger or finger into the hole on the battery release slider.
  2. Acer Chromebook C710-2847 Wireless Card Replacement: étape 2, image 1 de 2 Acer Chromebook C710-2847 Wireless Card Replacement: étape 2, image 2 de 2
    • Use the spudger to move the slider to the right and hold it there.
    • With the slider held, use your other hand to pull the battery back away from the laptop.
  3. Acer Chromebook C710-2847 Wireless Card Replacement, Acer Chromebook C710-2847 Back Cover Replacement: étape 3, image 1 de 1
    • This step will void your device warranty.
    • Use the screwdriver to pierce the warranty sticker.
    • Unscrew and remove the #0 6mm Phillips screw and set it aside.
  4. Acer Chromebook C710-2847 Wireless Card Replacement: étape 4, image 1 de 2 Acer Chromebook C710-2847 Wireless Card Replacement: étape 4, image 2 de 2
    • Slide the back panel towards you. The best spots to place your fingers are on the bumpers.
    • Lift on the front edge to remove the panel.
  5. Acer Chromebook C710-2847 Wireless Card Replacement, Wireless Card: étape 5, image 1 de 3 Acer Chromebook C710-2847 Wireless Card Replacement, Wireless Card: étape 5, image 2 de 3 Acer Chromebook C710-2847 Wireless Card Replacement, Wireless Card: étape 5, image 3 de 3
    • Use a spudger or your fingernails to lift up and unclip the two gold connectors on the top of the wireless card.
  6. Acer Chromebook C710-2847 Wireless Card Replacement: étape 6, image 1 de 1
    • Unscrew the black #0 3mm Phillips screw at the top right of the wireless card.
  7. Acer Chromebook C710-2847 Wireless Card Replacement: étape 7, image 1 de 2 Acer Chromebook C710-2847 Wireless Card Replacement: étape 7, image 2 de 2
    • The wireless card will spring up.
    • Pull the wireless card up and out to remove it.
2 autres ont terminé cette réparation.
Bradley Pavy
Membre depuis le 09/30/13
1 257 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 13-3, Forte Fall 2013 Membre de l'équipe Cal Poly, Team 13-3, Forte Fall 2013
CPSU-FORTE-F13S13G3
5 membres
14 tutoriels rédigés
Un commentaire
If you replace the original wifi card, how do you get Chrome OS to recognize, or find and download driver for Intel AC 7260 wifi card?
Thanks.
When Ze - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 9
Total : 5,990
