Aller au contenu principal
Acer Chromebook C710-2847 Back Cover Replacement
Ce dont vous avez besoin
  1. Acer Chromebook C710-2847 Back Cover Replacement, Battery: étape 1, image 1 de 2 Acer Chromebook C710-2847 Back Cover Replacement, Battery: étape 1, image 2 de 2
    • Place the laptop on a flat surface with the bottom side facing up.
    • Place the tip of a spudger or finger into the hole on the battery release slider.
  2. Acer Chromebook C710-2847 Back Cover Replacement: étape 2, image 1 de 2 Acer Chromebook C710-2847 Back Cover Replacement: étape 2, image 2 de 2
    • Use the spudger to move the slider to the right and hold it there.
    • With the slider held, use your other hand to pull the battery back away from the laptop.
  3. Acer Chromebook C710-2847 Back Cover Replacement, Acer Chromebook C710-2847 Back Cover Replacement: étape 3, image 1 de 1
    • This step will void your device warranty.
    • Use the screwdriver to pierce the warranty sticker.
    • Unscrew and remove the #0 6mm Phillips screw and set it aside.
  4. Acer Chromebook C710-2847 Back Cover Replacement: étape 4, image 1 de 2 Acer Chromebook C710-2847 Back Cover Replacement: étape 4, image 2 de 2
    • Slide the back panel towards you. The best spots to place your fingers are on the bumpers.
    • Lift on the front edge to remove the panel.
9 autres ont terminé cette réparation.
Bradley Pavy
Membre depuis le 09/30/13
1 257 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 13-3, Forte Fall 2013 Membre de l'équipe Cal Poly, Team 13-3, Forte Fall 2013
CPSU-FORTE-F13S13G3
5 membres
14 tutoriels rédigés
Un commentaire
Once you have the back cover off, you can insert aluminum foil into a tiny connector, which will allow you to flash the BIOS and boot any operating system, not just ChromeOS. Using this method, I completely wiped ChromeOS from my C710 and installed Ubuntu 16.04 LTS. Definitely worth it, because now I have a sub-$300 Linux netbook with a removable battery, standard keyboard with CAPS lock (most Chromebooks don't), and no ugly Windows key.
Uncle Happy - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 6,381
