Aller au contenu principal
Acer Chromebook C710-2847 Battery Replacement
Ce dont vous avez besoin
  1. Acer Chromebook C710-2847 Battery Replacement, Battery: étape 1, image 1 de 2 Acer Chromebook C710-2847 Battery Replacement, Battery: étape 1, image 2 de 2
    • Place the laptop on a flat surface with the bottom side facing up.
    • Place the tip of a spudger or finger into the hole on the battery release slider.
  2. Acer Chromebook C710-2847 Battery Replacement: étape 2, image 1 de 2 Acer Chromebook C710-2847 Battery Replacement: étape 2, image 2 de 2
    • Use the spudger to move the slider to the right and hold it there.
    • With the slider held, use your other hand to pull the battery back away from the laptop.
16 autres ont terminé cette réparation.
Adam Whitmarsh
Membre depuis le 09/30/13
1 059 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 13-3, Forte Fall 2013 Membre de l'équipe Cal Poly, Team 13-3, Forte Fall 2013
CPSU-FORTE-F13S13G3
5 membres
14 tutoriels rédigés
5 commentaires
I actually used a ball point pin instead of a spudger (its dark, I'm female and I am not walking to Office Max in this neighborhood by myself). And voici, the battery came off. Now to see if the damned computer will reboot.
Daphne Macklin - Réponse
I have a C710-2856, which uses a 14.8V battery. All of the extended batteries say they won't work on the 14.8V battery .Does anyone know of an extended battery that WOULD work with the 14.8V version of this Chromebook. I can up the RAM to 16GB, and I can put any SSD, but the only weakness left is the short battery life.
Tom Dison - Réponse
I wish I had an answer for you! I'm looking into the same thing. All the extended batteries are 11.1 v and not compatible with the 14.8 v need of the C710-2856. Did you ever get an answer to this? perhaps elsewhere? Thanks!
Cornell Gunter -
i have a C710-2815? what kind of battery do i need for a replacement
sudanna soetome - Réponse
I ordered this battery before seeing this. Not only is voltage incorrect, but it does not latch.
https://www.amazon.com/gp/product/B00XDT...
Slides on, but connector mismatch and will not lock into place.
Sending back.
Also the BUY PARTS amazon button at the top right of this article is a 404 error.
When Ze - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 11
Total : 30,774
