Aller au contenu principal
Introduction
This guide explains how to remove the battery. Before removing the battery, the front panel assembly will also need to be removed. Once the battery is reached, you will need to unplug some cables and unscrew some screws.
Pièces
Aucune pièce spécifiée.
  1. Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver. Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
    • Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
  2. Pry the back panel open with the plastic opening tool. Pry the back panel open with the plastic opening tool.
    • Pry the back panel open with the plastic opening tool.
  3. Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
    • Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
  4. Carefully pull out the battery wire connected to the battery port. Carefully pull out the battery wire connected to the battery port.
    • Carefully pull out the battery wire connected to the battery port.
  5. Slowly lift the battery to remove it from the Chromebook.
    • Slowly lift the battery to remove it from the Chromebook.
3 autres ont terminé cette réparation.
Jason Bechtold
Membre depuis le 19/10/2017
582 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S4-G7, Julie Fall 2017 Membre de l'équipe UMass Dartmouth, Team S4-G7, Julie Fall 2017
UMASSD-JULIE-F17S4G7
1 membre
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 1,121
