Aller au contenu principal
Introduction
This guide will show you how to replace your Acer Chromebook C720-2827 display. You will need to follow some prerequisite guides including the back cover and battery replacement prior to beginning. Use this guide if your display is broken or has died.
Pièces
Aucune pièce spécifiée.
  1. Acer Chromebook C720-2827 Display Replacement, Back Panel Assembly: étape 1, image 1 de 2 Acer Chromebook C720-2827 Display Replacement, Back Panel Assembly: étape 1, image 2 de 2
    • Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
  2. Acer Chromebook C720-2827 Display Replacement: étape 2, image 1 de 2 Acer Chromebook C720-2827 Display Replacement: étape 2, image 2 de 2
    • Pry the back panel open with the plastic opening tool.
  3. Acer Chromebook C720-2827 Display Replacement, Battery: étape 3, image 1 de 1
    • Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
  4. Acer Chromebook C720-2827 Display Replacement: étape 4, image 1 de 2 Acer Chromebook C720-2827 Display Replacement: étape 4, image 2 de 2
    • Carefully pull out the battery wire connected to the battery port.
  5. Acer Chromebook C720-2827 Display Replacement: étape 5, image 1 de 1
    • Slowly lift the battery to remove it from the Chromebook.
  6. Acer Chromebook C720-2827 Display Replacement, Display: étape 6, image 1 de 2 Acer Chromebook C720-2827 Display Replacement, Display: étape 6, image 2 de 2
    • Using your fingers, pull the tape off of the display connector.
  7. Acer Chromebook C720-2827 Display Replacement: étape 7, image 1 de 2 Acer Chromebook C720-2827 Display Replacement: étape 7, image 2 de 2
    • Use the spudger to disconnect the display connector from the motherboard.
  8. Acer Chromebook C720-2827 Display Replacement: étape 8, image 1 de 3 Acer Chromebook C720-2827 Display Replacement: étape 8, image 2 de 3 Acer Chromebook C720-2827 Display Replacement: étape 8, image 3 de 3
    • Use the spudger to gently disconnect the black and white coaxial antenna cables off of the WLAN card.
  9. Acer Chromebook C720-2827 Display Replacement: étape 9, image 1 de 3 Acer Chromebook C720-2827 Display Replacement: étape 9, image 2 de 3 Acer Chromebook C720-2827 Display Replacement: étape 9, image 3 de 3
    • Using your Phillips #1 screwdriver, unscrew two 3.7mm screws from the right display hinge.
    • Using your Phillips #1 screwdriver, unscrew two 5.7mm screws from the left display hinge.
    • When removing the display, be careful to unthread the black coaxial antenna cable underneath the motherboard from the opposite side of the panel.
Sarah Westberg
Membre depuis le 11/03/2019
15 425 Réputation
65 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
145 membres
15 551 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 236
