Aller au contenu principal
Acer Chromebook C720-2827 Trackpad Replacement
Ce dont vous avez besoin
  1. Acer Chromebook C720-2827 Trackpad Replacement, Back Panel Assembly: étape 1, image 1 de 2 Acer Chromebook C720-2827 Trackpad Replacement, Back Panel Assembly: étape 1, image 2 de 2
    • Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
  2. Acer Chromebook C720-2827 Trackpad Replacement: étape 2, image 1 de 2 Acer Chromebook C720-2827 Trackpad Replacement: étape 2, image 2 de 2
    • Pry the back panel open with the plastic opening tool.
  3. Acer Chromebook C720-2827 Trackpad Replacement, Battery: étape 3, image 1 de 1
    • Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
  4. Acer Chromebook C720-2827 Trackpad Replacement: étape 4, image 1 de 2 Acer Chromebook C720-2827 Trackpad Replacement: étape 4, image 2 de 2
    • Carefully pull out the battery wire connected to the battery port.
  5. Acer Chromebook C720-2827 Trackpad Replacement: étape 5, image 1 de 1
    • Slowly lift the battery to remove it from the Chromebook.
  6. Acer Chromebook C720-2827 Trackpad Replacement, Trackpad: étape 6, image 1 de 3 Acer Chromebook C720-2827 Trackpad Replacement, Trackpad: étape 6, image 2 de 3 Acer Chromebook C720-2827 Trackpad Replacement, Trackpad: étape 6, image 3 de 3
    • Using a spudger, pry up the locking bar of the ZIF connector on the trackpad and remove the ribbon cable.
  7. Acer Chromebook C720-2827 Trackpad Replacement: étape 7, image 1 de 3 Acer Chromebook C720-2827 Trackpad Replacement: étape 7, image 2 de 3 Acer Chromebook C720-2827 Trackpad Replacement: étape 7, image 3 de 3
    • Peel off the clear plastic covering the screws.
    • Remove the five grey 2.5 mm screws securing the trackpad with a Phillips #1 screwdriver.
    • Remove another four silver 2.9mm Phillips #1 screws from the silver bracket atop the trackpad with your driver.
  8. Acer Chromebook C720-2827 Trackpad Replacement: étape 8, image 1 de 2 Acer Chromebook C720-2827 Trackpad Replacement: étape 8, image 2 de 2
    • Lift up the silver bracket.
    • Remove the trackpad by lifting it up from the case.
Austin Blakely
Membre depuis le 03/11/19
19 389 Réputation
53 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
136 membres
16 560 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 9
Total : 237
