Introduction
If the I/O board for your Acer Chromebook (model C731-C8VE) is damaged, defective or generally needs a replacement, this guide is here to help you.
In order to remove the I/O board you must first remove the ribbon cable and the screw that is connected to the I/O board. After this is completed you should be able to gently slide the I/O board out and replace it.
You will of course need to ensure that your laptop is completely powered off and not connected to a source of power to avoid risk of electrocution or other injury.
Ce dont vous avez besoin
Push up the latch connected to the ribbon cable on the I/O board with a nylon spudger.
Gently remove the cable from the I/O board with tweezers.
Remove the 5 mm screw from the I/O board using a JIS #00 screwdriver.
