Aller au contenu principal
Acer Chromebook C731-C8VE Trackpad Replacement
Ce dont vous avez besoin
  1. Acer Chromebook C731-C8VE Trackpad Replacement, Trackpad: étape 1, image 1 de 1
    • Place the Chromebook face down.
  2. Acer Chromebook C731-C8VE Trackpad Replacement: étape 2, image 1 de 1
    • Make sure to completely turn off the device before beginning this step.
    • Use a JIS #00 screwdriver to remove the 11 screws on the underside of the laptop.
    • These 2 mm screws have washers and must be placed in these specific areas.
    • The 2 mm screws marked orange do not have washers attached and will be placed on the left and right of the device.
  3. Acer Chromebook C731-C8VE Trackpad Replacement: étape 3, image 1 de 3 Acer Chromebook C731-C8VE Trackpad Replacement: étape 3, image 2 de 3 Acer Chromebook C731-C8VE Trackpad Replacement: étape 3, image 3 de 3
    • Use the iFixit opening tool to remove the keyboard from the device by prying it loose from the base.
  4. Acer Chromebook C731-C8VE Trackpad Replacement: étape 4, image 1 de 3 Acer Chromebook C731-C8VE Trackpad Replacement: étape 4, image 2 de 3 Acer Chromebook C731-C8VE Trackpad Replacement: étape 4, image 3 de 3
    • Detach the wires connecting the keyboard and the touchpad to the motherboard by lifting the black connectors up.
  5. Acer Chromebook C731-C8VE Trackpad Replacement: étape 5, image 1 de 2 Acer Chromebook C731-C8VE Trackpad Replacement: étape 5, image 2 de 2
    • Use the JIS #00 screwdriver to remove four 1mm screws that connect the trackpad to the device.
  6. Acer Chromebook C731-C8VE Trackpad Replacement: étape 6, image 1 de 2 Acer Chromebook C731-C8VE Trackpad Replacement: étape 6, image 2 de 2
    • Do this step slowly to ensure that you do not damage the trackpad or the device.
    • Remove the trackpad from the base of the device.
Justin Menninger
Membre depuis le 03/21/22
400 Réputation
3 tutoriels rédigés
Équipe
0Commentaires sur le guide
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 6
Total : 222
