Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
The battery replacement for the Acer Chromebook C740 requires removing several screws, prying the pack panel off, and unplugging the battery. This disassembly is required for several other replacement guides.
  1. Power down the Chromebook and disconnect the power adapter.
    • Power down the Chromebook and disconnect the power adapter.
  2. Place the chromebook bottom side up on a flat surface. Remove the thirteen 7 mm screws with a Phillips #0 screwdriver.
    • Place the chromebook bottom side up on a flat surface.
    • Remove the thirteen 7 mm screws with a Phillips #0 screwdriver.
  3. Insert the plastic opening tool into the slit near the hinges and pry upwards to lift the back panel. Applying pressure may be necessary. A click indicates the panel is ready to come off. Applying pressure may be necessary. A click indicates the panel is ready to come off.
    • Insert the plastic opening tool into the slit near the hinges and pry upwards to lift the back panel.
    • Applying pressure may be necessary. A click indicates the panel is ready to come off.
  4. Unplug the white 8-wire battery connector from the motherboard  by using a spudger to push the two L-shaped indentations towards the battery. The connector is a tight fit. This process requires going back-and-forth between the two indentations and plenty of patience. The connector is a tight fit. This process requires going back-and-forth between the two indentations and plenty of patience.
    • Unplug the white 8-wire battery connector from the motherboard by using a spudger to push the two L-shaped indentations towards the battery.
    • The connector is a tight fit. This process requires going back-and-forth between the two indentations and plenty of patience.
  5. Remove the the two 3.7 mm screws with a Phillips #0 screwdriver. Remove the the two 3.7 mm screws with a Phillips #0 screwdriver.
    • Remove the the two 3.7 mm screws with a Phillips #0 screwdriver.
  6. Lift the battery from the frame.
    • Lift the battery from the frame.
6 autre(s) ont terminé cette réparation.
Flor De La Rosa
Membre depuis le 25/04/2017
757 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team S22-G2, Livingston Spring 2017 Membre de l'équipe Cal Poly, Team S22-G2, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G2
4 membres
12 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 68
Total : 2,175
