Aller au contenu principal
Acer Chromebook CB3-431-C5EX Power Port Replacement
Ce dont vous avez besoin
  1. Acer Chromebook CB3-431-C5EX Power Port Replacement, Bottom Panel: étape 1, image 1 de 1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Turn device over so the bottom panel is facing you.
  2. Acer Chromebook CB3-431-C5EX Power Port Replacement: étape 2, image 1 de 1
    • Remove the eight 4mm Phillips #0 screws.
    • Remove the two 6mm Phillips #0 screws.
  3. Acer Chromebook CB3-431-C5EX Power Port Replacement: étape 3, image 1 de 2 Acer Chromebook CB3-431-C5EX Power Port Replacement: étape 3, image 2 de 2
    • Insert a plastic opening tool into the crack between the bottom panel and the side of the computer.
    • Gently pry the panel off the computer by continuously pulling up and on the panel and moving the plastic opening tool around the crack until the panel comes off.
    • There are several clips holding the cover in place.
    • Remove the bottom panel and set it aside.
  4. Acer Chromebook CB3-431-C5EX Power Port Replacement, Power Port: étape 4, image 1 de 2 Acer Chromebook CB3-431-C5EX Power Port Replacement, Power Port: étape 4, image 2 de 2
    • Remove the four 4mm Phillips #0 screws from the hinge plates on the two corners of the laptop.
    • Remove any manufacturers tape holding in the wires.
  5. Acer Chromebook CB3-431-C5EX Power Port Replacement: étape 5, image 1 de 2 Acer Chromebook CB3-431-C5EX Power Port Replacement: étape 5, image 2 de 2
    • Disconnect black and white wires from the wireless adapter by gently pulling up on the metal connectors with your fingernail.
  6. Acer Chromebook CB3-431-C5EX Power Port Replacement: étape 6, image 1 de 2 Acer Chromebook CB3-431-C5EX Power Port Replacement: étape 6, image 2 de 2
    • Open hinges to the screen. and then slide base of the computer off of the hinges.
    • It is easiest to do this by holding the hinges in place and opening the entire laptop. Then close the laptop while letting the hinges remain open.
    • This will detach the base of the computer from the screen in order to allow better access to the power port.
  7. Acer Chromebook CB3-431-C5EX Power Port Replacement: étape 7, image 1 de 2 Acer Chromebook CB3-431-C5EX Power Port Replacement: étape 7, image 2 de 2
    Outil utilisé dans cette étape :
    • Detach the power port plug from the main circuit board by grabbing it by the sides of the plastic with the tweezers and gently pulling it out.
  8. Acer Chromebook CB3-431-C5EX Power Port Replacement: étape 8, image 1 de 2 Acer Chromebook CB3-431-C5EX Power Port Replacement: étape 8, image 2 de 2
    • Remove the power port entirely from the computer by pulling up on the plastic portion of the port with a plastic opening tool.
14 autres ont terminé cette réparation.
Cayley Ho
Membre depuis le 04/18/17
548 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team S17-G3, Banghart Spring 2017 Membre de l'équipe Cal Poly, Team S17-G3, Banghart Spring 2017
CPSU-BANGHART-S17S17G3
5 membres
10 tutoriels rédigés
7 commentaires
I need a link to the replacement part for a new power port!
Tom Adams - Réponse
Require a link for a new power port
Kieran Davies - Réponse
Do a search for 50.GC2N5.003
Scott Hardin - Réponse
The guide is excellent and easy to follow.
However, a word of advice. If you do want to disconnect the wires be warned that their terminals are extremely small and difficult to get back if damaged. It appears to be a soft metal and if you do not line them up exactly the holes on the wireless chip will distort and you will find it impossible to put them back on. I speak from experience and the only solution is to either buy a new wireless adaptor or to solder the wires on.
That itself is fiddly and I have yet to find out if it has worked on mine. (I need to buy a soldering iron). As the wire is an antenna only, I am assured that it should still work even without a connection, provided that you are near the router.
My recommended procedure is not to disconnect the wires but instead to take the small screw out of the adaptor itself and then press down and slide it out. That will free the two halves of the computer without separating the wires.
Ron Seymour - Réponse
Thanks for giving my Chromebook a new lease on life! I followed all of the steps except (1) disconnecting the wireless adapter and (2) separating the base from the screen. Those two steps seemed unnecessary, and since I don't repair my own devices regularly, I was worried I might cause more trouble for myself than the convenience was worth. The rest was very helpful and clearly written/highlighted in the photos. Thank you again!
K.E.H. Ellis - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 16
30 derniers jours : 47
Total : 10,024
