Aller au contenu principal
Acer Chromebook CP5-471-C0EX Motherboard Replacement
Ce dont vous avez besoin
  1. Acer Chromebook CP5-471-C0EX Motherboard Replacement, Battery: étape 1, image 1 de 2 Acer Chromebook CP5-471-C0EX Motherboard Replacement, Battery: étape 1, image 2 de 2
    • Carefully detach the ribbon cable connecting the battery and the motherboard.
  2. Acer Chromebook CP5-471-C0EX Motherboard Replacement: étape 2, image 1 de 1
    • Use your hands to lift the battery out of the device.
  3. Acer Chromebook CP5-471-C0EX Motherboard Replacement, Trackpad: étape 3, image 1 de 3 Acer Chromebook CP5-471-C0EX Motherboard Replacement, Trackpad: étape 3, image 2 de 3 Acer Chromebook CP5-471-C0EX Motherboard Replacement, Trackpad: étape 3, image 3 de 3
    • Disconnect the wide black ribbon cable from the motherboard using an iFixit opening tool.
    • Disconnect the blue-tipped ribbon from the motherboard.
    • Be careful not to damage the motherboard while removing the ribbon cables.
  4. Acer Chromebook CP5-471-C0EX Motherboard Replacement: étape 4, image 1 de 3 Acer Chromebook CP5-471-C0EX Motherboard Replacement: étape 4, image 2 de 3 Acer Chromebook CP5-471-C0EX Motherboard Replacement: étape 4, image 3 de 3
    • Remove the golden tape connecting the trackpad to the plastic divider using an iFixit opening tool.
    • Peel back the black plastic divider that separates the motherboard and trackpad.
  5. Acer Chromebook CP5-471-C0EX Motherboard Replacement: étape 5, image 1 de 2 Acer Chromebook CP5-471-C0EX Motherboard Replacement: étape 5, image 2 de 2
    • Remove four 3 mm screws from the trackpad using a Phillips #1 screwdriver.
  6. Acer Chromebook CP5-471-C0EX Motherboard Replacement: étape 6, image 1 de 2 Acer Chromebook CP5-471-C0EX Motherboard Replacement: étape 6, image 2 de 2
    • Carefully remove the trackpad from the device.
  7. Acer Chromebook CP5-471-C0EX Motherboard Replacement, Wi-Fi Card: étape 7, image 1 de 1
    • Gently pull the black and white cables up to disconnect them from the Wi-Fi card.
  8. Acer Chromebook CP5-471-C0EX Motherboard Replacement: étape 8, image 1 de 2 Acer Chromebook CP5-471-C0EX Motherboard Replacement: étape 8, image 2 de 2
    • Remove the single 3 mm screw using a Phillips #1 screwdriver.
  9. Acer Chromebook CP5-471-C0EX Motherboard Replacement: étape 9, image 1 de 1
    • Gently pull the wireless card away from the motherboard to remove it.
  10. Acer Chromebook CP5-471-C0EX Motherboard Replacement, Fan: étape 10, image 1 de 2 Acer Chromebook CP5-471-C0EX Motherboard Replacement, Fan: étape 10, image 2 de 2
  11. Acer Chromebook CP5-471-C0EX Motherboard Replacement: étape 11, image 1 de 3 Acer Chromebook CP5-471-C0EX Motherboard Replacement: étape 11, image 2 de 3 Acer Chromebook CP5-471-C0EX Motherboard Replacement: étape 11, image 3 de 3
    • Unwind the Wi-Fi card wires from the side of the fan.
    • The wires need to be pulled down and around the first hook, as seen in image two.
    • Pull the black and white cables under the second hook and away from the fan.
  12. Acer Chromebook CP5-471-C0EX Motherboard Replacement: étape 12, image 1 de 3 Acer Chromebook CP5-471-C0EX Motherboard Replacement: étape 12, image 2 de 3 Acer Chromebook CP5-471-C0EX Motherboard Replacement: étape 12, image 3 de 3
    • Pull wires so they are out the way.
    • Loosen the six screws from the fan and heat sink.
    • The two screws closest to the fan cannot be removed from the fan, but will still loosen from the case.
  13. Acer Chromebook CP5-471-C0EX Motherboard Replacement: étape 13, image 1 de 3 Acer Chromebook CP5-471-C0EX Motherboard Replacement: étape 13, image 2 de 3 Acer Chromebook CP5-471-C0EX Motherboard Replacement: étape 13, image 3 de 3
    • Gently lift the fan out of the case, but do not remove it fully; there is still one more cable attached.
    • Pull the cable out of its socket on the motherboard.
    • Remove the fan from the laptop.
  14. Acer Chromebook CP5-471-C0EX Motherboard Replacement, Motherboard: étape 14, image 1 de 2 Acer Chromebook CP5-471-C0EX Motherboard Replacement, Motherboard: étape 14, image 2 de 2
    • Push on the sides of the connector to gently disconnect the speaker cable from the motherboard.
  15. Acer Chromebook CP5-471-C0EX Motherboard Replacement: étape 15, image 1 de 3 Acer Chromebook CP5-471-C0EX Motherboard Replacement: étape 15, image 2 de 3 Acer Chromebook CP5-471-C0EX Motherboard Replacement: étape 15, image 3 de 3
    • Use an iFixit opening tool to pry the display cable up from the motherboard.
  16. Acer Chromebook CP5-471-C0EX Motherboard Replacement: étape 16, image 1 de 2 Acer Chromebook CP5-471-C0EX Motherboard Replacement: étape 16, image 2 de 2
    • Remove seven 3 mm screws from the motherboard using a Phillips #1 screwdriver.
  17. Acer Chromebook CP5-471-C0EX Motherboard Replacement: étape 17, image 1 de 1
    • Remove the motherboard from the laptop.
Naomi Salas
Membre depuis le 04/05/22
244 Réputation
2 tutoriels rédigés
Équipe
Gateway, Team 1-1, Saknee Spring 2022 Membre de l'équipe Gateway, Team 1-1, Saknee Spring 2022
GCC-SAKNEE-S22S1G1
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 2
Total : 337
