Aller au contenu principal
Acer Chromebook CP5-471-C0EX Trackpad Replacement
Ce dont vous avez besoin
  1. Acer Chromebook CP5-471-C0EX Trackpad Replacement, Back Cover: étape 1, image 1 de 2 Acer Chromebook CP5-471-C0EX Trackpad Replacement, Back Cover: étape 1, image 2 de 2
    • Turn off the laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
  2. Acer Chromebook CP5-471-C0EX Trackpad Replacement: étape 2, image 1 de 3 Acer Chromebook CP5-471-C0EX Trackpad Replacement: étape 2, image 2 de 3 Acer Chromebook CP5-471-C0EX Trackpad Replacement: étape 2, image 3 de 3
    • Remove twelve 7 mm screws from the back of the laptop using a Phillips #1 screwdriver.
  3. Acer Chromebook CP5-471-C0EX Trackpad Replacement: étape 3, image 1 de 2 Acer Chromebook CP5-471-C0EX Trackpad Replacement: étape 3, image 2 de 2
    • Use a Jimmy to pry apart the bottom of the case from the laptop.
    • Be careful not to warp or crack the case.
  4. Acer Chromebook CP5-471-C0EX Trackpad Replacement, Battery: étape 4, image 1 de 2 Acer Chromebook CP5-471-C0EX Trackpad Replacement, Battery: étape 4, image 2 de 2
    • Carefully detach the ribbon cable connecting the battery and the motherboard.
  5. Acer Chromebook CP5-471-C0EX Trackpad Replacement: étape 5, image 1 de 1
    • Use your hands to lift the battery out of the device.
  6. Acer Chromebook CP5-471-C0EX Trackpad Replacement, Trackpad: étape 6, image 1 de 3 Acer Chromebook CP5-471-C0EX Trackpad Replacement, Trackpad: étape 6, image 2 de 3 Acer Chromebook CP5-471-C0EX Trackpad Replacement, Trackpad: étape 6, image 3 de 3
    • Disconnect the wide black ribbon cable from the motherboard using an iFixit opening tool.
    • Disconnect the blue-tipped ribbon from the motherboard.
    • Be careful not to damage the motherboard while removing the ribbon cables.
  7. Acer Chromebook CP5-471-C0EX Trackpad Replacement: étape 7, image 1 de 3 Acer Chromebook CP5-471-C0EX Trackpad Replacement: étape 7, image 2 de 3 Acer Chromebook CP5-471-C0EX Trackpad Replacement: étape 7, image 3 de 3
    • Remove the golden tape connecting the trackpad to the plastic divider using an iFixit opening tool.
    • Peel back the black plastic divider that separates the motherboard and trackpad.
  8. Acer Chromebook CP5-471-C0EX Trackpad Replacement: étape 8, image 1 de 2 Acer Chromebook CP5-471-C0EX Trackpad Replacement: étape 8, image 2 de 2
    • Remove four 3 mm screws from the trackpad using a Phillips #1 screwdriver.
  9. Acer Chromebook CP5-471-C0EX Trackpad Replacement: étape 9, image 1 de 2 Acer Chromebook CP5-471-C0EX Trackpad Replacement: étape 9, image 2 de 2
    • Carefully remove the trackpad from the device.
Trestin Bachtiger
Membre depuis le 02/08/22
239 Réputation
1 tutoriel rédigé
Équipe
Gateway, Team 1-1, Saknee Spring 2022 Membre de l'équipe Gateway, Team 1-1, Saknee Spring 2022
GCC-SAKNEE-S22S1G1
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 9
Total : 102
