Aller au contenu principal
Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement
Ce dont vous avez besoin
  1. Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement, Back Cover: étape 1, image 1 de 2 Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement, Back Cover: étape 1, image 2 de 2
    • Turn off the laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
  2. Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement: étape 2, image 1 de 3 Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement: étape 2, image 2 de 3 Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement: étape 2, image 3 de 3
    • Remove twelve 7 mm screws from the back of the laptop using a Phillips #1 screwdriver.
  3. Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement: étape 3, image 1 de 2 Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement: étape 3, image 2 de 2
    • Use a Jimmy to pry apart the bottom of the case from the laptop.
    • Be careful not to warp or crack the case.
  4. Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement, Battery: étape 4, image 1 de 2 Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement, Battery: étape 4, image 2 de 2
    • Carefully detach the ribbon cable connecting the battery and the motherboard.
  5. Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement: étape 5, image 1 de 1
    • Use your hands to lift the battery out of the device.
  6. Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement, Wi-Fi Card: étape 6, image 1 de 1
    • Gently pull the black and white cables up to disconnect them from the Wi-Fi card.
  7. Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement: étape 7, image 1 de 2 Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement: étape 7, image 2 de 2
    • Remove the single 3 mm screw using a Phillips #1 screwdriver.
  8. Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement: étape 8, image 1 de 1
    • Gently pull the wireless card away from the motherboard to remove it.
Aida mohamed
Membre depuis le 02/08/22
186 Réputation
1 tutoriel rédigé
Équipe
Gateway, Team 1-1, Saknee Spring 2022 Membre de l'équipe Gateway, Team 1-1, Saknee Spring 2022
GCC-SAKNEE-S22S1G1
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 6
Total : 134
