Introduction
This guide will show you how to replace the battery of your Acer Chromebook R 11 CB5-132T-C9KK. The battery allows you to use the computer when it's not plugged in to the power outlet.
If you're unsure if the battery is the problem, take a look at the Acer Chromebook R 11 CB5-132T-C9KK Troubleshooting page for more information.
Before beginning the guide, turn off the device and unplug it from the charger.
Ce dont vous avez besoin
Turn the laptop over so that the backside is facing up.
Use a Phillips #0 screwdriver to remove nine screws along the perimeter of the back case.
Use an opening tool to pry the case around the perimeter and gently release the clips attaching the back case to the front.
Lift the back case off of the Chromebook.
