Aller au contenu principal
Acer Chromebook R11 C738T-C44Z Wireless Card Replacement
Ce dont vous avez besoin
  1. Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Back Cover: étape 1, image 1 de 3 Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Back Cover: étape 1, image 2 de 3 Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Back Cover: étape 1, image 3 de 3
    • Lay the laptop with the back side up.
    • Use a Phillips #1 screwdriver to remove eleven 3 mm screws.
    • Use the opening tool to pry the back cover off gently by placing it in the seam and working your way around the perimeter.
  2. Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Wireless Card: étape 2, image 1 de 2 Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Wireless Card: étape 2, image 2 de 2
    • Disconnect the two antenna cables (one black and one white) that are attached to the wireless card.
  3. Acer Chromebook R11 C738T-C44Z Wireless Card Replacement: étape 3, image 1 de 1
    • Use a Phillips #1 screwdriver to remove the single 3 mm screw that secures the wireless card.
  4. Acer Chromebook R11 C738T-C44Z Wireless Card Replacement: étape 4, image 1 de 2 Acer Chromebook R11 C738T-C44Z Wireless Card Replacement: étape 4, image 2 de 2
    • Carefully slide the wireless card out of its socket from the motherboard.
Connie Hernandez
Membre depuis le 09/01/21
517 Réputation
4 tutoriels rédigés
Équipe
Gateway, Team 1-4, Saknee Fall 2021 Membre de l'équipe Gateway, Team 1-4, Saknee Fall 2021
GCC-SAKNEE-F21S1G4
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 10
Total : 314
