Introduction
Replacing a motherboard is usually a last resort option as the motherboard is where all the data and files are in a Chromebook. Only replace a Chromebook motherboard if you are certain it is a motherboard that is malfunctioning.
Ce dont vous avez besoin
Using a Phillips screwdriver, remove all eleven 7.0 mm screws from the bottom of the Chromebook.
Orient the laptop so the motherboard side is further away from you in a landscape position.
Use the flat end of the spudger to lift the the ZIF connector retaining flaps securing the three small ribbon cables.
9 autres ont terminé cette réparation.
