Aller au contenu principal
Acer Chromebook Spin 11 R751TN-C5P3 Battery Replacement
Ce dont vous avez besoin
  1. Acer Chromebook Spin 11 R751TN-C5P3 Battery Replacement, Battery: étape 1, image 1 de 1
    • Flip the Chromebook face down.
    • Use a Phillips #0 screwdriver to remove the twelve 6 mm screws that secure the bottom cover.
  2. Acer Chromebook Spin 11 R751TN-C5P3 Battery Replacement: étape 2, image 1 de 2 Acer Chromebook Spin 11 R751TN-C5P3 Battery Replacement: étape 2, image 2 de 2
    • Insert an opening tool in the seam between the outer covers. Pushing down on the edge of the opening tool will cause the cover to lift up and reveal the internal components.
  3. Acer Chromebook Spin 11 R751TN-C5P3 Battery Replacement: étape 3, image 1 de 1
    • Grab the connecting cord between the battery and the motherboard and pull towards you to disconnect.
    • Remove any tape holding the battery cord down by pulling up on it.
  4. Acer Chromebook Spin 11 R751TN-C5P3 Battery Replacement: étape 4, image 1 de 1
    • The battery is no longer connected to the Chromebook allowing you to lift up and remove the battery.
Bailey Johnson
Membre depuis le 03/21/22
691 Réputation
5 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 29
Total : 961
