Aller au contenu principal
Acer Chromebook Spin 11 R751TN-C5P3 Track Pad Replacement
Ce dont vous avez besoin
  1. Acer Chromebook Spin 11 R751TN-C5P3 Track Pad Replacement, Battery: étape 1, image 1 de 1
    • Flip the Chromebook face down.
    • Use a Phillips #0 screwdriver to remove the twelve 6 mm screws that secure the bottom cover.
  2. Acer Chromebook Spin 11 R751TN-C5P3 Track Pad Replacement: étape 2, image 1 de 2 Acer Chromebook Spin 11 R751TN-C5P3 Track Pad Replacement: étape 2, image 2 de 2
    • Insert an opening tool in the seam between the outer covers. Pushing down on the edge of the opening tool will cause the cover to lift up and reveal the internal components.
  3. Acer Chromebook Spin 11 R751TN-C5P3 Track Pad Replacement: étape 3, image 1 de 1
    • Grab the connecting cord between the battery and the motherboard and pull towards you to disconnect.
    • Remove any tape holding the battery cord down by pulling up on it.
  4. Acer Chromebook Spin 11 R751TN-C5P3 Track Pad Replacement: étape 4, image 1 de 1
    • The battery is no longer connected to the Chromebook allowing you to lift up and remove the battery.
  5. Acer Chromebook Spin 11 R751TN-C5P3 Track Pad Replacement, Track Pad: étape 5, image 1 de 1
    • Pull the tape back and unplug the cable connecting the track pad to the motherboard by gently pulling back on it.
  6. Acer Chromebook Spin 11 R751TN-C5P3 Track Pad Replacement: étape 6, image 1 de 1
    • Use a Phillips #0 screwdriver to remove the four 3 mm screws that secure the track pad in place.
    • 3 of the screws are located below the black film that must be lifted up to expose them.
  7. Acer Chromebook Spin 11 R751TN-C5P3 Track Pad Replacement: étape 7, image 1 de 1
    • Lift up on the track pad to remove it out of the Chromebook.
Bailey Johnson
Membre depuis le 03/21/22
691 Réputation
5 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 10
Total : 410
