Introduction
The purpose of this guide is to walk you through replacing the battery in a Acer Chromebook Spin 15 CP315-1H-P1K8 laptop. If the battery in your laptop is no longer holding a charge, use this guide to remove and replace the battery. Make sure to be careful when handling the battery. Handle the back of the computer carefully to make sure it is not broken.
Ce dont vous avez besoin
Flip the computer over so that the back is facing up.
Remove the twelve 6mm Phillips #1 screws from the bottom of the laptop.
Remove the ribbon cable by pulling the plastic connector that is connected to the motherboard out.
