Aller au contenu principal
Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement
Ce dont vous avez besoin
  1. Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement, Back Cover: étape 1, image 1 de 2 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement, Back Cover: étape 1, image 2 de 2
    • Make sure the device is fully powered off.
    • Flip the computer over so that the back is facing up.
    • Remove the twelve 6mm Phillips #1 screws from the bottom of the laptop.
  2. Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: étape 2, image 1 de 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: étape 2, image 2 de 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: étape 2, image 3 de 3
    • Use the iFixit opening tools as wedges to pry the back of the laptop off.
    • Go slow, making sure not to snap the plastic. With enough of a gap made, you can use your hand to finish taking off the back.
  3. Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement, Display Screen: étape 3, image 1 de 2 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement, Display Screen: étape 3, image 2 de 2
    • Remove the five 6mm Phillips #1 screws from the hinges on either side of the laptop.
  4. Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: étape 4, image 1 de 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: étape 4, image 2 de 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: étape 4, image 3 de 3
    • Unplug the camera/microphone ribbon cable from the circuit board.
    • Remove the single 3mm Phillips #1 screw from the Intel core.
    • Unplug the cable from the circuit board.
  5. Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: étape 5, image 1 de 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: étape 5, image 2 de 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: étape 5, image 3 de 3
    • Use the plastic opening tool, create a gap between the back and front of the display.
    • Lift the front out with your hands.
  6. Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement, Microphone: étape 6, image 1 de 1
    • Remove the two 3 mm Phillips #1 black screws from the microphone at the top of the display cover.
  7. Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: étape 7, image 1 de 2 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: étape 7, image 2 de 2
    • Remove the microphone component from the rest of the computer by detaching the connected wire.
    • The camera component of the laptop is connected to the same wire, so remove this as well.
    • The camera is only held down with adhesives, so there is no need to use any tools.
  8. Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: étape 8, image 1 de 2 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: étape 8, image 2 de 2
    • Remove the microphone and camera wire out from around the display screen.
    • Remove the ribbon cable at the bottom of the display screen to completely free the wire.
    • Carefully remove the adhesive tape and take out the ribbon cable.
  9. Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: étape 9, image 1 de 2 Acer Chromebook Spin 15 CP315-1H-P1K8 Microphone Replacement: étape 9, image 2 de 2
    • Remove the microphone from the laptop.
Ian Sullivan
Membre depuis le 10/29/19
116 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S4-G1, Saloman Fall 2019 Membre de l'équipe UMass Dartmouth, Team S4-G1, Saloman Fall 2019
UMASSD-SALOMAN-F19S4G1
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 14
Total : 739
