Aller au contenu principal
Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement
Ce dont vous avez besoin
  1. Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement, Back Cover: étape 1, image 1 de 2 Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement, Back Cover: étape 1, image 2 de 2
    • Make sure the device is fully powered off.
    • Flip the computer over so that the back is facing up.
    • Remove the twelve 6mm Phillips #1 screws from the bottom of the laptop.
  2. Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement: étape 2, image 1 de 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement: étape 2, image 2 de 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement: étape 2, image 3 de 3
    • Use the iFixit opening tools as wedges to pry the back of the laptop off.
    • Go slow, making sure not to snap the plastic. With enough of a gap made, you can use your hand to finish taking off the back.
  3. Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement, Battery: étape 3, image 1 de 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement, Battery: étape 3, image 2 de 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement, Battery: étape 3, image 3 de 3
    • Remove the ribbon cable by pulling the plastic connector that is connected to the motherboard out.
  4. Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement: étape 4, image 1 de 1
    • Remove the battery from the laptop by hand.
  5. Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement, Touchpad: étape 5, image 1 de 1
    • Detach the ribbon cable from the touchpad.
  6. Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement: étape 6, image 1 de 2 Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement: étape 6, image 2 de 2
    • Remove the tan adhesive tape that is covering the touchpad to expose the screws holding it in.
    • Remove the three, 3mm long screws that are holding the touchpad in place.
  7. Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement: étape 7, image 1 de 2 Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement: étape 7, image 2 de 2
    • Gently push the touchpad out with your hand.
Evan Costa
Membre depuis le 10/29/19
503 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team S4-G1, Saloman Fall 2019 Membre de l'équipe UMass Dartmouth, Team S4-G1, Saloman Fall 2019
UMASSD-SALOMAN-F19S4G1
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 13
Total : 530
