Introduction
There are many reasons to replace your hard drive. You may be running out of storage space or want to upgrade to a solid state drive. Perhaps you are encountering errors with your data. This guide will get you fixed up in no time.
Ensure the laptop is powered down prior to beginning.
  • Ensure the laptop is powered down prior to beginning.
  • Turn the laptop over with the battery closest to your body.
  • The battery release is just above the left side of the battery.
Ajouter un commentaire
Insert a small tipped screwdriver or similar tool into the release.
  • Insert a small tipped screwdriver or similar tool into the release.
  • Gently slide the release all the way to the left.
  • You should hear a sound after the slide is all the way left. This lets you know the battery has disengaged.
  • With your hands on each end of the battery, carefully pull towards your body to remove.
  • Using a #0 Phillips screwdriver, remove a total of eighteen identical 8mm Phillips screws and set them aside.
  • Rotate the laptop 180 degrees so that the battery compartment is now furthest away from your body.
  • Turn the laptop over so that you can easily open the screen to a vertical position.
  • Put your fingers under the top of the keyboard assembly directly below the Acer logo.
  • Carefully pull up on the center until you hear the tabs disengage from the bottom.
  • Work your way around the seam with the plastic opening tool carefully prying the base and top cover apart.
  • If you have difficulty with the plastic opening tool, use a metal spudger but be more cautious to not damage or mar your laptop case.
  • When the two halves are separated, carefully lift up the front of the keyboard and touchpad assembly.
  • You will see three ribbon cables attached to the motherboard.
  • Closest to the ribbon cable on the zero insertion force (ZIF) connector is a white locking tab.
  • Carefully lift up on the locking tab with the plastic opening tool to release the ribbon cable. (Picture 2)
  • Remove the ribbon cable from the connector.
  • Closest to the ribbon cable on the ZIF connector is a black locking tab.
  • On each side of the large connector there are two white tabs.
  • Carefully push away from you with the plastic opening tool on each white tab to release the cable. (Picture 2)
  • Once all three ribbon cables are disconnected, lift off the top cover with the keyboard and touchpad.
  • The hard drive and carriage are at the lower right of the laptop.
  • Using the plastic opening tool, carefully lift up on the black locking tab of the ZIF connector to release the USB port ribbon cable.
  • Move the USB port ribbon cable out of the way
  • Using a #0 Phillips screwdriver, remove the two 4mm screws securing the hard drive carriage in place.
  • Hold the right side of the laptop in place with your right hand.
  • Put the fingers of your left hand along the top edge of the hard drive carriage.
  • Push the hard drive carriage towards your right hand to disconnect it from the motherboard.
  • This procedure may require more force then other procedures.
  • Lift up on the edge of the hard drive carriage closest to your body to remove the carriage.
  • If doing the motherboard replacement guide, skip the next step.
  • There are two 3mm Phillips screws holding the hard drive into the carriage. One on either side of the carriage.
  • Hold the hard drive carriage with your non-dominant hand along one side. Ensure one of the Phillips screws is visible.
  • Using a #0 Phillips screwdriver, remove the 3mm screw to release the side of the hard drive from the carriage.
  • Repeat the two previous procedures to remove the second 3mm Phillips screw freeing the hard drive from the carriage.
Aaron Weissman
Membre depuis le 23/10/2017
701 Réputation
8 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G8, Bailey Fall 2017 Membre de l'équipe UMass Dartmouth, Team S3-G8, Bailey Fall 2017
UMASSD-BAILEY-F17S3G8
3 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 59
