Introduction
The motherboard is like the central nervous system of your computer. If you have issues with your hardware, a faulty motherboard or a loose connection may be the problem.
Ce dont vous avez besoin
Power down the laptop prior to beginning.
Turn the laptop over with the battery closest to your body.
Using a #0 Phillips screwdriver, remove a total of eighteen identical 8mm Phillips screws and set them aside.
Locate the WiFi card. It is just below the fan and has a white coaxial cable and a black coaxial cable attached to it.
Grab the section of the white coaxial cable behind the brass connection using ESD safe blunt nose metal tweezers.
Carefully lift the white coaxial cable up and forward to disconnect the it from the WiFi card.
Repeat the previous two bullet points to disconnect the black coaxial cable from the WiFi card.
Locate the CPU cooling fan in the upper left corner of the laptop.
Using a #0 Phillips screwdriver, remove the two 4.5 mm screws that secure the fan to the case.
Locate the hard drive and its carriage at the lower right corner of the laptop.
Release the USB port ribbon cable by using the plastic opening tool to carefully lift up the black locking tab of the ZIF connector.
Move the USB port ribbon cable to the side.
Locate the two 3 mm Phillips screws holding the hard drive into the carriage. There is one screw on each side of the carriage.
Hold the hard drive carriage with your non-dominant hand along one side. Ensure one of the Phillips screws is visible.
Using a #0 Phillips screwdriver, remove the 3 mm screw to release the side of the hard drive from the carriage.
Repeat the two previous bullet marks to remove the second 3 mm Phillips screw. This should also free the hard drive from the carriage.
Carefully lift up on the right edge of the motherboard near the hard drive connector.
With minimal force, pull the motherboard to the right freeing the ports on the left from the case.
Put down the right side and allow the motherboard to rest in the case.
Lift the left side of the motherboard up and turn it over so the ports are now facing right.
3 autres ont terminé cette réparation.
Un commentaire
Hi is this the DDR4 with Geforce MX Series Vcard variant or the older DDR3?
