Aller au contenu principal
Acer Iconia A1-830 Rear Facing Camera Replacement
Ce dont vous avez besoin
  1. Acer Iconia A1-830 Rear Facing Camera Replacement, Disassembling Acer Iconia A1-830 Back Panel: étape 1, image 1 de 2 Acer Iconia A1-830 Rear Facing Camera Replacement, Disassembling Acer Iconia A1-830 Back Panel: étape 1, image 2 de 2
    • Prepare your working space. The ideal work space has a flat, level surface that is clean and well lit.
    • Shut down your Acer Iconia A1-830.
    • Remove any cables or exterior covers from your tablet.
    • Place it on your work space, with the screen facing up.
  2. Acer Iconia A1-830 Rear Facing Camera Replacement: étape 2, image 1 de 2 Acer Iconia A1-830 Rear Facing Camera Replacement: étape 2, image 2 de 2
    • Wedge the plastic opening tool into the tiny gap between the white plastic front bezel and the aluminum rear panel.
    • Do not try to pry apart the top edge on the front side near the front-facing camera.
  3. Acer Iconia A1-830 Rear Facing Camera Replacement, Battery: étape 3, image 1 de 2 Acer Iconia A1-830 Rear Facing Camera Replacement, Battery: étape 3, image 2 de 2
    • Remove the small clear plastic cover on top of the battery cable with the nylon or metal spudger.
  4. Acer Iconia A1-830 Rear Facing Camera Replacement: étape 4, image 1 de 1
    • Remove the battery cable by lifting it up with the pointy end of the black nylon spudger.
  5. Acer Iconia A1-830 Rear Facing Camera Replacement: étape 5, image 1 de 2 Acer Iconia A1-830 Rear Facing Camera Replacement: étape 5, image 2 de 2
    • Un-stick the battery from the metal plate using the black nylon spudger.
    • Be careful not to puncture the battery while removing it.
  6. Acer Iconia A1-830 Rear Facing Camera Replacement, Rear Facing Camera: étape 6, image 1 de 1
    • Remove the piece of black tape covering the rear facing camera ribbon cable connector.
  7. Acer Iconia A1-830 Rear Facing Camera Replacement: étape 7, image 1 de 2 Acer Iconia A1-830 Rear Facing Camera Replacement: étape 7, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Lift up the small white lever on the the ribbon cable connector with the metal tweezers to remove the ribbon cable.
    • Lift out the rear facing camera from the plastic frame with the metal tweezers.
Brendan Coveney
Membre depuis le 10/18/15
593 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-6, Catania Fall 2015 Membre de l'équipe UMass Dartmouth, Team 4-6, Catania Fall 2015
UMASSD-CATANIA-F15S4G6
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 405
