Aller au contenu principal
Acer Iconia A110 Battery Replacement
Ce dont vous avez besoin
  1. Acer Iconia A110 Battery Replacement, Battery: étape 1, image 1 de 2 Acer Iconia A110 Battery Replacement, Battery: étape 1, image 2 de 2
    • Before taking apart your tablet, make sure the device is powered off.
    • Pry open the right side of case with the plastic opening tool. If necessary, keep a tool lodged into the side to keep the case from closing.
    • During this process, the volume button and/or power button may fall out.
  2. Acer Iconia A110 Battery Replacement: étape 2, image 1 de 3 Acer Iconia A110 Battery Replacement: étape 2, image 2 de 3 Acer Iconia A110 Battery Replacement: étape 2, image 3 de 3
    • Pry open the left side of the case with a plastic opening tool. The backside of the tablet should now separate completely from the front.
  3. Acer Iconia A110 Battery Replacement: étape 3, image 1 de 3 Acer Iconia A110 Battery Replacement: étape 3, image 2 de 3 Acer Iconia A110 Battery Replacement: étape 3, image 3 de 3
    • Using the plastic opening tool and spudger, carefully pry up the battery from the case.
    • You should hear the adhesive ripping as you do this.
    • Once the battery is no longer adhered to the case, detach the dongle that connects the battery to the motherboard.
3 autres ont terminé cette réparation.
Andrea
Membre depuis le 04/14/14
757 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 3-42, Maness Spring 2014 Membre de l'équipe Cal Poly, Team 3-42, Maness Spring 2014
CPSU-MANESS-S14S3G42
4 membres
5 tutoriels rédigés
Un commentaire
Where can you purchase the battery for acer iconia tab a110?
redd4167 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 21
30 derniers jours : 22
Total : 11,308
