Ce dont vous avez besoin
Pry open the right side of case with the plastic opening tool. If necessary, keep a tool lodged into the side to keep the case from closing.
With the Phillips #00 screwdriver, remove the following screws securing the motherboard to the back panel:
Two 2.0 mm screws (with the bigger head)
Four 2.5 mm screws (with the smaller head)
On the top right side of the motherboard, is the vibration motor. With tweezers, carefully pull the vibration motor out from underneath the motherboard.
With your fingers, carefully disconnect the cable securing the vibration motor to the motherboard. Set aside.
The next step is to pull out the ribbon cables connected to the motherboard.
Each ribbon cable has a sticker covering it; peel it off with tweezers.
Use tweezers to pull out the ribbon cable.
Carefully gripping the top of the camera connection cord, slowly pull down to remove the sticky tape from the tablet.
3 autres ont terminé cette réparation.
