Aller au contenu principal
Acer Iconia B1-710 Screen Replacement
Ce dont vous avez besoin
  1. Acer Iconia B1-710 Screen Replacement, Battery: étape 1, image 1 de 3 Acer Iconia B1-710 Screen Replacement, Battery: étape 1, image 2 de 3 Acer Iconia B1-710 Screen Replacement, Battery: étape 1, image 3 de 3
    • Open the back cover by prying the casing off with an opening tool.
    • Be careful to not pull pieces apart aggressively. There is a wire that could break.
  2. Acer Iconia B1-710 Screen Replacement: étape 2, image 1 de 3 Acer Iconia B1-710 Screen Replacement: étape 2, image 2 de 3 Acer Iconia B1-710 Screen Replacement: étape 2, image 3 de 3
    • Unplug the battery from the motherboard.
  3. Acer Iconia B1-710 Screen Replacement: étape 3, image 1 de 1
    • Remove the battery.
    • The battery is lightly glued in, so there may be some difficulty getting it out.
  4. Acer Iconia B1-710 Screen Replacement, Screen: étape 4, image 1 de 2 Acer Iconia B1-710 Screen Replacement, Screen: étape 4, image 2 de 2
    • Unscrew all five 3 mm #000 Phillips screws.
  5. Acer Iconia B1-710 Screen Replacement: étape 5, image 1 de 2 Acer Iconia B1-710 Screen Replacement: étape 5, image 2 de 2
    • Unplug the LCD ribbon.
  6. Acer Iconia B1-710 Screen Replacement: étape 6, image 1 de 2 Acer Iconia B1-710 Screen Replacement: étape 6, image 2 de 2
    • Unplug the orange ribbon.
  7. Acer Iconia B1-710 Screen Replacement: étape 7, image 1 de 3 Acer Iconia B1-710 Screen Replacement: étape 7, image 2 de 3 Acer Iconia B1-710 Screen Replacement: étape 7, image 3 de 3
    • Unplug the white wire from the motherboard.
    • Unplug the black wire from the motherboard.
  8. Acer Iconia B1-710 Screen Replacement: étape 8, image 1 de 1
    • Pull the motherboard off of the tablet.
  9. Acer Iconia B1-710 Screen Replacement: étape 9, image 1 de 1
    • Use a blow dryer to melt the glue holding the LCD display in place.
    • Patience is key. It will take a few minutes to melt the glue.
  10. Acer Iconia B1-710 Screen Replacement: étape 10, image 1 de 3 Acer Iconia B1-710 Screen Replacement: étape 10, image 2 de 3 Acer Iconia B1-710 Screen Replacement: étape 10, image 3 de 3
    • Peel the LCD display.
    • This piece is fragile and needs to be peeled with care.
    • Parts may be hot.
  11. Acer Iconia B1-710 Screen Replacement: étape 11, image 1 de 1
    • Use a blow dryer to melt the glue from the thin metal frame.
    • This piece is metal and will become hot during this process.
  12. Acer Iconia B1-710 Screen Replacement: étape 12, image 1 de 2 Acer Iconia B1-710 Screen Replacement: étape 12, image 2 de 2
    • Peel off the thin metal frame.
    • Be careful not to bend the frame as it is very thin.
  13. Acer Iconia B1-710 Screen Replacement: étape 13, image 1 de 1
    • Use a blow dryer to melt the glue between the metal frame and the screen.
    • The frame will get hot.
  14. Acer Iconia B1-710 Screen Replacement: étape 14, image 1 de 2 Acer Iconia B1-710 Screen Replacement: étape 14, image 2 de 2
    • Peel the frame from the screen.
    • Be careful when peeling the screen or it may sustain further damage.
Ryan Weber
Membre depuis le 03/26/17
358 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team S3-G5, Baechle Spring 2017 Membre de l'équipe IUPUI, Team S3-G5, Baechle Spring 2017
IUPUI-BAECHLE-S17S3G5
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 10
Total : 934
