Aller au contenu principal
Acer Iconia B1-710 Tablet Camera Replacement
Ce dont vous avez besoin
  1. Acer Iconia B1-710 Tablet Camera Replacement, Battery: étape 1, image 1 de 3 Acer Iconia B1-710 Tablet Camera Replacement, Battery: étape 1, image 2 de 3 Acer Iconia B1-710 Tablet Camera Replacement, Battery: étape 1, image 3 de 3
    • Open the back cover by prying the casing off with an opening tool.
    • Be careful to not pull pieces apart aggressively. There is a wire that could break.
  2. Acer Iconia B1-710 Tablet Camera Replacement: étape 2, image 1 de 3 Acer Iconia B1-710 Tablet Camera Replacement: étape 2, image 2 de 3 Acer Iconia B1-710 Tablet Camera Replacement: étape 2, image 3 de 3
    • Unplug the battery from the motherboard.
  3. Acer Iconia B1-710 Tablet Camera Replacement: étape 3, image 1 de 1
    • Remove the battery.
    • The battery is lightly glued in, so there may be some difficulty getting it out.
  4. Acer Iconia B1-710 Tablet Camera Replacement, Camera: étape 4, image 1 de 2 Acer Iconia B1-710 Tablet Camera Replacement, Camera: étape 4, image 2 de 2
    • Remove the five 3mm Phillips #000 screws. The location of the screws are shown in the above picture, circled in red.
    • Keep the removed screws in a safe place so they can be used later.
  5. Acer Iconia B1-710 Tablet Camera Replacement: étape 5, image 1 de 2 Acer Iconia B1-710 Tablet Camera Replacement: étape 5, image 2 de 2
    • Unplug the LCD by lifting the LCD plug from the white board. The location of the LCD plug is shown in the above picture, circled in red.
    • If you are having difficulty removing the LCD plug, use a spudger to gently lift it.
  6. Acer Iconia B1-710 Tablet Camera Replacement: étape 6, image 1 de 2 Acer Iconia B1-710 Tablet Camera Replacement: étape 6, image 2 de 2
    • Next, unplug the orange strip from the motherboard by gently lifting it. The location of the orange strip is shown in the above picture, circled in red.
    • The orange strip is delicate; be careful when unplugging it and make sure it doesn't tear.
  7. Acer Iconia B1-710 Tablet Camera Replacement: étape 7, image 1 de 3 Acer Iconia B1-710 Tablet Camera Replacement: étape 7, image 2 de 3 Acer Iconia B1-710 Tablet Camera Replacement: étape 7, image 3 de 3
    • Unplug the white wire, shown above, circled in red.
    • Unplug the black wire, shown above, circled in orange.
  8. Acer Iconia B1-710 Tablet Camera Replacement: étape 8, image 1 de 1
    • Gently, remove the motherboard by carefully lifting it.
  9. Acer Iconia B1-710 Tablet Camera Replacement: étape 9, image 1 de 3 Acer Iconia B1-710 Tablet Camera Replacement: étape 9, image 2 de 3 Acer Iconia B1-710 Tablet Camera Replacement: étape 9, image 3 de 3
    • Remove the camera from the motherboard with the spudger.
    • Be careful not to damage the camera plug; it is very delicate.
To reassemble your device, follow the above instructions in reverse order.
Ryan Weber
Membre depuis le 03/26/17
358 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team S3-G5, Baechle Spring 2017 Membre de l'équipe IUPUI, Team S3-G5, Baechle Spring 2017
IUPUI-BAECHLE-S17S3G5
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 8
Total : 352
