Aller au contenu principal
Acer Iconia B1-720 Battery Replacement
Ce dont vous avez besoin
  1. Acer Iconia B1-720 Battery Replacement, Rear Case: étape 1, image 1 de 3 Acer Iconia B1-720 Battery Replacement, Rear Case: étape 1, image 2 de 3 Acer Iconia B1-720 Battery Replacement, Rear Case: étape 1, image 3 de 3
    • Insert a plastic opening tool into a gap near the charging port at the top of the device. Slide the tool in either direction along the device.
  2. Acer Iconia B1-720 Battery Replacement: étape 2, image 1 de 3 Acer Iconia B1-720 Battery Replacement: étape 2, image 2 de 3 Acer Iconia B1-720 Battery Replacement: étape 2, image 3 de 3
    • Slide the tool along until you have completely separated the rear cover.
    • If needed, place the first tool in the gap created to hold this gap open and use a second tool to pry the remaining portion of the rear cover off.
  3. Acer Iconia B1-720 Battery Replacement: étape 3, image 1 de 2 Acer Iconia B1-720 Battery Replacement: étape 3, image 2 de 2
    • Once all the sides have been separated, you should be able to simply lift the cover off of the device.
  4. Acer Iconia B1-720 Battery Replacement, Battery: étape 4, image 1 de 2 Acer Iconia B1-720 Battery Replacement, Battery: étape 4, image 2 de 2
    • Peel back the plastic tape covering the battery connector.
  5. Acer Iconia B1-720 Battery Replacement: étape 5, image 1 de 1
    • Use the plastic opening tool to lift the battery off of the back panel. The adhesive used is strong so apply force during removal.
  6. Acer Iconia B1-720 Battery Replacement: étape 6, image 1 de 3 Acer Iconia B1-720 Battery Replacement: étape 6, image 2 de 3 Acer Iconia B1-720 Battery Replacement: étape 6, image 3 de 3
    • Lift the battery off of the panel gently. This will disconnect the battery connector from the motherboard.
5 autres ont terminé cette réparation.
Kervis Boston
Membre depuis le 03/18/15
479 Réputation
3 tutoriels rédigés
Équipe
Michigan Tech, Team 1-1, Lauer Spring 2015 Membre de l'équipe Michigan Tech, Team 1-1, Lauer Spring 2015
MTU-LAUER-S15S1G1
2 membres
5 tutoriels rédigés
2 commentaires
Why the battery has a 4 pin connector? I tried to buy another generic battery but it got only 2 cables, don't know how to replace :(
Tadeu - Réponse
I just wanted to throw a red flag out there…I broke my connector off the motherboard trying to reinstall the four-pin connection…can anyone advise?
John Merritt - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 8
Total : 2,884
