Aller au contenu principal
Acer Iconia B1-720 Microphone/Speaker Replacement
Ce dont vous avez besoin
  1. Acer Iconia B1-720 Microphone/Speaker Replacement, Rear Case: étape 1, image 1 de 3 Acer Iconia B1-720 Microphone/Speaker Replacement, Rear Case: étape 1, image 2 de 3 Acer Iconia B1-720 Microphone/Speaker Replacement, Rear Case: étape 1, image 3 de 3
    • Insert a plastic opening tool into a gap near the charging port at the top of the device. Slide the tool in either direction along the device.
  2. Acer Iconia B1-720 Microphone/Speaker Replacement: étape 2, image 1 de 3 Acer Iconia B1-720 Microphone/Speaker Replacement: étape 2, image 2 de 3 Acer Iconia B1-720 Microphone/Speaker Replacement: étape 2, image 3 de 3
    • Slide the tool along until you have completely separated the rear cover.
    • If needed, place the first tool in the gap created to hold this gap open and use a second tool to pry the remaining portion of the rear cover off.
  3. Acer Iconia B1-720 Microphone/Speaker Replacement: étape 3, image 1 de 2 Acer Iconia B1-720 Microphone/Speaker Replacement: étape 3, image 2 de 2
    • Once all the sides have been separated, you should be able to simply lift the cover off of the device.
  4. Acer Iconia B1-720 Microphone/Speaker Replacement, Microphone/Speaker: étape 4, image 1 de 3 Acer Iconia B1-720 Microphone/Speaker Replacement, Microphone/Speaker: étape 4, image 2 de 3 Acer Iconia B1-720 Microphone/Speaker Replacement, Microphone/Speaker: étape 4, image 3 de 3
    • Pry the speaker away from the device using the plastic opening tool. This may require a little force due to the adhesive that is on the device.(Battery is not shown in this picture for image
    • Tug gently on microphone to remove from slot.
  5. Acer Iconia B1-720 Microphone/Speaker Replacement: étape 5, image 1 de 2 Acer Iconia B1-720 Microphone/Speaker Replacement: étape 5, image 2 de 2
    • Unwind the wire from the running channel.
    • To remove microphone, follow same steps.
  6. Acer Iconia B1-720 Microphone/Speaker Replacement: étape 6, image 1 de 2 Acer Iconia B1-720 Microphone/Speaker Replacement: étape 6, image 2 de 2
    • Unplug connector from motherboard.
    • Follow same procedure to remove microphone.
    • Unplug the microphone in a similar fashion as with the speaker.
Phillip Keavey
Membre depuis le 03/17/15
319 Réputation
2 tutoriels rédigés
Équipe
Michigan Tech, Team 1-1, Lauer Spring 2015 Membre de l'équipe Michigan Tech, Team 1-1, Lauer Spring 2015
MTU-LAUER-S15S1G1
2 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 7
Total : 691
