Introduction
In order to remove the motherboard, you will need both a plastic opening tool and a Phillips #00 screwdriver. In addition to that, all the tape surrounding the motherboard will need to be removed.
Ce dont vous avez besoin
Open media port cover at the top of the tablet.
Use the Phillips #00 screwdriver to remove the 1 mm screw.
2 autres ont terminé cette réparation.
Un commentaire
The button flex cable retaining clip is broken, do you have this available?
