Aller au contenu principal
Acer Iconia One 7 Battery Replacement
Ce dont vous avez besoin
  1. Acer Iconia One 7 Battery Replacement, Battery: étape 1, image 1 de 1
    • Begin prying the front from the back on any side of the tablet. Gently work your way around the tablet with the prying tool.
  2. Acer Iconia One 7 Battery Replacement: étape 2, image 1 de 1
    • Using a plastic opening tool, separate the back cover from the main device.
    • Open each side continuously to ensure all sides have been separated.
  3. Acer Iconia One 7 Battery Replacement: étape 3, image 1 de 1
    • Turn the tablet over so the battery is facing up.
  4. Acer Iconia One 7 Battery Replacement: étape 4, image 1 de 2 Acer Iconia One 7 Battery Replacement: étape 4, image 2 de 2
    • Carefully pull back the black tape covering the battery lead connector.
    • Disconnect connection with the board by pulling up on the wire with the plastic opening tool.
  5. Acer Iconia One 7 Battery Replacement: étape 5, image 1 de 3 Acer Iconia One 7 Battery Replacement: étape 5, image 2 de 3 Acer Iconia One 7 Battery Replacement: étape 5, image 3 de 3
    Outil utilisé dans cette étape :
    Plastic Cards
    $2.99
    J'achète
    • Using a plastic card or opening pick, separate the battery from the rest of the device.
    • Do not use a metal spudger like seen in the example photos. Use a plastic card to avoid bending or rupturing the battery.
6 autres ont terminé cette réparation.
Ahmad Kayali
Membre depuis le 09/01/15
458 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 8-5, Eyestone Fall 2015 Membre de l'équipe USF Tampa, Team 8-5, Eyestone Fall 2015
USFT-EYESTONE-F15S8G5
3 membres
5 tutoriels rédigés
4 commentaires
is there a replacement batt that can fit here or other brand that can fit? like from samsing tab? acer battery sucks
Stanley So - Réponse
Thank you for this guide, replaced my battery (very easy with guide) and now my tablet works good. Also saved me some money. Thanks
vlamar14 - Réponse
My acer iconia one 7 battery model is 308292 wnd there is no tutorial regarding replacing battery. Thank
wantalktasol - Réponse
Where I can order the new battery part?
melanieloa3 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 21
Total : 18,246
