Aller au contenu principal
Acer Iconia One 7 Motherboard Replacement
Ce dont vous avez besoin
    • Reminder: Turn off device before you start opening your tablet.
  1. Acer Iconia One 7 Motherboard Replacement: étape 2, image 1 de 1
    • Begin at any side of the tablet.
    • With a plastic opening tool, begin taking apart the back cover from the tablet by working along the edges.
    • Use caution when prying the lid open to avoid damaging your tablet.
  2. Acer Iconia One 7 Motherboard Replacement: étape 3, image 1 de 1
    • Using a plastic opening tool, separate the back cover from the main device
    • Open each side continuously to ensure all sides have been separated,
  3. Acer Iconia One 7 Motherboard Replacement: étape 4, image 1 de 1
    • Turn tablet over.
    • Lay the tablet on a flat surface with the screen facing down. Locate the copper cover along the outside of the tablet.
  4. Acer Iconia One 7 Motherboard Replacement: étape 5, image 1 de 1
    • Carefully peel back the copper foil to reveal the motherboard.
  5. Acer Iconia One 7 Motherboard Replacement: étape 6, image 1 de 1
    • Peel tape back to expose connections.
  6. Acer Iconia One 7 Motherboard Replacement: étape 7, image 1 de 2 Acer Iconia One 7 Motherboard Replacement: étape 7, image 2 de 2
    • There are several sets of wires connected to the motherboard as shown in the images. Carefully disconnect each set of wires.
  7. Acer Iconia One 7 Motherboard Replacement: étape 8, image 1 de 2 Acer Iconia One 7 Motherboard Replacement: étape 8, image 2 de 2
    • Use a JIS screw bit #00 to remove screws around the motherboard using the provided image to locate each screw.
  8. Acer Iconia One 7 Motherboard Replacement: étape 9, image 1 de 1
    • Gently pull out motherboard.
4 autres ont terminé cette réparation.
Michael
Membre depuis le 09/03/15
519 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 8-5, Eyestone Fall 2015 Membre de l'équipe USF Tampa, Team 8-5, Eyestone Fall 2015
USFT-EYESTONE-F15S8G5
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 19
30 derniers jours : 27
Total : 2,619
