Aller au contenu principal
Acer Iconia One 8 Battery Replacement
Ce dont vous avez besoin
  1. Acer Iconia One 8 Battery Replacement, Battery: étape 1, image 1 de 2 Acer Iconia One 8 Battery Replacement, Battery: étape 1, image 2 de 2
    • To remove the back panel, insert an opening tool into the small crack between the screen and back panel. Gently pry open the tablet.
  2. Acer Iconia One 8 Battery Replacement: étape 2, image 1 de 1
    • Remove the black piece of tape that is holding the red, yellow, and white wires in place.
  3. Acer Iconia One 8 Battery Replacement: étape 3, image 1 de 1
    • Once the tape has been removed, gently pinch the wires and remove them from the socket. They should come out easily.
  4. Acer Iconia One 8 Battery Replacement: étape 4, image 1 de 1
    • Carefully work a plastic spudger underneath the battery and pry it free.
    • Use an iOpener or carefully apply heat with a heat gun to soften the adhesive under the battery.
    • Be careful not to bend or puncture the battery.
2 autres ont terminé cette réparation.
Josh Cooper
Membre depuis le 04/13/17
319 Réputation
3 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 12
Total : 2,855
