Aller au contenu principal
Acer Iconia One 8 Front Camera Replacement
Ce dont vous avez besoin
  1. Acer Iconia One 8 Front Camera Replacement, Screen: étape 1, image 1 de 2 Acer Iconia One 8 Front Camera Replacement, Screen: étape 1, image 2 de 2
    • Begin by opening the back panel.
    • Wedge a plastic opening tool in between the front and back shell and gently separate.
  2. Acer Iconia One 8 Front Camera Replacement: étape 2, image 1 de 3 Acer Iconia One 8 Front Camera Replacement: étape 2, image 2 de 3 Acer Iconia One 8 Front Camera Replacement: étape 2, image 3 de 3
    • Peel back all pieces of tape indicated in picture.
    • There are three pieces of tape total (2 Black and 1 Silver).
  3. Acer Iconia One 8 Front Camera Replacement: étape 3, image 1 de 3 Acer Iconia One 8 Front Camera Replacement: étape 3, image 2 de 3 Acer Iconia One 8 Front Camera Replacement: étape 3, image 3 de 3
    • Disconnect all cables from the device.
    • There should be 5 total.
  4. Acer Iconia One 8 Front Camera Replacement: étape 4, image 1 de 3 Acer Iconia One 8 Front Camera Replacement: étape 4, image 2 de 3 Acer Iconia One 8 Front Camera Replacement: étape 4, image 3 de 3
    • Remove the nine 3mm screws using the Phillips #000 screwdriver.
  5. Acer Iconia One 8 Front Camera Replacement: étape 5, image 1 de 1
    • Remove and separate the back plating (top) from the glass screen (bottom).
  6. Acer Iconia One 8 Front Camera Replacement, Motherboard: étape 6, image 1 de 2 Acer Iconia One 8 Front Camera Replacement, Motherboard: étape 6, image 2 de 2
    • Disconnect the metal tabs connecting the battery to the motherboard frame.
  7. Acer Iconia One 8 Front Camera Replacement: étape 7, image 1 de 2 Acer Iconia One 8 Front Camera Replacement: étape 7, image 2 de 2
    • Disconnect the cable for the back camera.
  8. Acer Iconia One 8 Front Camera Replacement: étape 8, image 1 de 1
    • Flip the metal plating to reveal the front camera.
  9. Acer Iconia One 8 Front Camera Replacement: étape 9, image 1 de 2 Acer Iconia One 8 Front Camera Replacement: étape 9, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Use tweezers to carefully remove the front camera from the adhesive on the motherboard.
  10. Acer Iconia One 8 Front Camera Replacement: étape 10, image 1 de 3 Acer Iconia One 8 Front Camera Replacement: étape 10, image 2 de 3 Acer Iconia One 8 Front Camera Replacement: étape 10, image 3 de 3
    • Flip the device back over.
    • Remove the motherboard from the metallic frame by feeding the back camera and front camera cable through the port.
    • Remove the front camera from the device.
  11. Acer Iconia One 8 Front Camera Replacement, Front Camera: étape 11, image 1 de 3 Acer Iconia One 8 Front Camera Replacement, Front Camera: étape 11, image 2 de 3 Acer Iconia One 8 Front Camera Replacement, Front Camera: étape 11, image 3 de 3
    • Separate the front-facing camera from the back camera.
    • The two cameras are connected by glue and can be pulled apart.
Dustin Newland
Membre depuis le 11/06/19
343 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team S1-G2, Stella Fall 2019 Membre de l'équipe IUPUI, Team S1-G2, Stella Fall 2019
IUPUI-STELLA-F19S1G2
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 126
