Ce dont vous avez besoin
Power off the device
Remove any cables that might be connected to your device
Make sure the device is placed on a flat surface with the display screen facing up
Use your fingers to pull back and remove the yellow plastic tape covering the battery cable.
Outil utilisé dans cette étape :Heavy-Duty Spudger$4.99
Use the flat side of the heavy duty spudger to lift the small black plastic flap.
Presque terminé !
