Aller au contenu principal
Acer Iconia Tab 8 A1-860 Speaker Replacement
Ce dont vous avez besoin
  1. Acer Iconia Tab 8 A1-860 Speaker Replacement, Rear Case: étape 1, image 1 de 2 Acer Iconia Tab 8 A1-860 Speaker Replacement, Rear Case: étape 1, image 2 de 2
    • Insert the plastic opening tool into the seam between the back case and the display.
    • Work the plastic opening tool around the seam until the rear case separates from the display.
  2. Acer Iconia Tab 8 A1-860 Speaker Replacement: étape 2, image 1 de 1
    • Separate the rear case and place the tablet face side down.
  3. Acer Iconia Tab 8 A1-860 Speaker Replacement, Battery: étape 3, image 1 de 1
    • Using a spudger, work the tool under the battery connector located above the battery on the left side, and lift it free.
  4. Acer Iconia Tab 8 A1-860 Speaker Replacement: étape 4, image 1 de 3 Acer Iconia Tab 8 A1-860 Speaker Replacement: étape 4, image 2 de 3 Acer Iconia Tab 8 A1-860 Speaker Replacement: étape 4, image 3 de 3
    • Pull firmly on the black tabs, located at the top left and bottom right of the battery.
    • The clear adhesive strips attached to the tabs are quite stretchy. Don't give up; keep pulling the tabs until the battery releases. The strips will not be reusable.
    • Remove the battery.
  5. Acer Iconia Tab 8 A1-860 Speaker Replacement, Speaker: étape 5, image 1 de 2 Acer Iconia Tab 8 A1-860 Speaker Replacement, Speaker: étape 5, image 2 de 2
    • Use a Phillips #000 screwdriver to remove the three 3 mm screws.
  6. Acer Iconia Tab 8 A1-860 Speaker Replacement: étape 6, image 1 de 2 Acer Iconia Tab 8 A1-860 Speaker Replacement: étape 6, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Use tweezers to gently lift off the connector and wires attached to the speakers.
    • Remove the speakers from the device.
2 autres ont terminé cette réparation.
Michael Buchanan
Membre depuis le 04/01/19
361 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S2-G3, Harley Spring 2019 Membre de l'équipe IUPUI, Team S2-G3, Harley Spring 2019
IUPUI-HARLEY-S19S2G3
3 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 148
