Introduction
Replace the speaker in your Acer Iconia Tab 500.
Pièces
Aucune pièce nécessaire.
To start, gently separate one corner of the case using the black spudger.
  • To start, gently separate one corner of the case using the black spudger.
Ajouter un commentaire
Once you have successfully pried the spudger in between the front case and back case, continue do so around the entire tablet until the back case is completely disconnected.
  • Once you have successfully pried the spudger in between the front case and back case, continue do so around the entire tablet until the back case is completely disconnected.
  • Locate the 4 screws and cable that hold in the two speakers.
    • Use the Phillips #1 screwdriver to remove these 2mm black screws.
    • Remove the 2mm silver screws.
      • Not all 4 screws are going to be the same kind. This will not affect the speaker replacement.
    • Connector Cable
  • Carefully remove the connector cable by pushing on the rim of black plastic insert.
  • Unfortunately, the top speaker is a wedged under the motherboard.
  • To get this speaker out, use the spudger and gently pry it out.
Kyle Libby
Membre depuis le 07/04/2014
945 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 7-23, Regan Spring 2014 Membre de l'équipe Cal Poly, Team 7-23, Regan Spring 2014
CPSU-REGAN-S14S7G23
4 membres
16 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 9
Total : 1,576
