Pièces
Aucune pièce nécessaire.
To start, gently separate one corner of the case using the black spudger.
  • To start, gently separate one corner of the case using the black spudger.
Ajouter un commentaire
Once you have successfully pried the spudger in between the front case and back case, continue do so around the entire tablet until the back case is completely disconnected.
  • Once you have successfully pried the spudger in between the front case and back case, continue do so around the entire tablet until the back case is completely disconnected.
  • Remove the 5mm screws that are securing the battery to the rest of the tablet.
    • Use the Phillips #00 Screwdriver to remove the 5mm screws.
  • Use the sharper end of the spudger to disconnect the battery from the mother board.
    • The battery connector will slide off.
  • After setting aside the battery, remove the two 5mm screws holding the metal plate over the USB port.
  • Find and remove the silver 5mm screw holding down the metal cover opposite the USB port.
  • Disconnect the blue cable by gently lifting the flap.
  • Remove the indicated 2mm screw holding the speaker in place.
  • Pull up the metal panel just enough to allow access, then remove the USB port.
4 autre(s) ont terminé cette réparation.
Sam Macy
Membre depuis le 01/04/2014
1 089 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 7-23, Regan Spring 2014 Membre de l'équipe Cal Poly, Team 7-23, Regan Spring 2014
CPSU-REGAN-S14S7G23
4 membres
16 tutoriels rédigés
Awesome I love the visual of the steps. Thank you!
_Samsunz
samiam6 - Réponse
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 23
Total : 2,979
